SOURCE: Canon GL2 shuts down automatically while in record mode
Turn off the power saver mode. I did it and it works!
SOURCE: blank lcd screen
wires have come off the ccd ! canon will fix free of charge,go to canon support
SOURCE: xti wont power up
appears to be a defect and not user serviceable.
sorry for the news.
good luck.
mark.
SOURCE: Canon SD400 LCD screen does not work
I too had the problem (described above) -- of seeing the purplish vertical curtain whenever I looked in my Canon PowerShot S410's LCD monitor.
I contacted Canon, they sent me a prepaid shipping label I could use at my local UPS store; they repaired the problem and then shipped the camera back to me. I received the camera just now and the problem seems to have been resolved.
Thank you, FixYa experts, for identifying the problem and indicating that Canon was fixing it at no charge.
admanmavo
SOURCE: cann't eject cassette from Canon ZR60
I had a similar problem last few days with my ZR60.
The problem I had was that the tape won't eject and on repeated attempts to eject it would eject as if it had a mind of its own.
I was messing with it a little bit and realized that the door was not opening fully. Being a delicate item I didn't realize that I was not fully opening the door may be because there was a little friction in the pivot pins or what ever.
Try to gently swing the door open fully and see if it helps.
Since I discovered this problem I tried 10-12 times, and every time it would eject the tape and load it.
I was almost going to give up this camcorder last night thank GOD, I am able to use it.
Good Luck to you.
