Lost all passwords to Dell laptop? Refer to how to unlock Dell laptop when you lost all password and are locked out Dell laptop.
Refer to this:http://www.fixya.com/support/t9165017-un...
Try Windows Password Recovery Tool 3.0 to reset dell laptop password.
More detail about:
http://www.windowspasswordsrecovery.com/crack-dell-laptop-password.htm
This happened very often and no need to be worried as you will find a lot of method to recover the lost password. Specially, this tutorial about Dell laptop password reset.
You can make a bootable Recovery Console CD by downloading an ISO file and burning it to a CD.
The bootable ISO image file you need to download is called:
xp_rec_con.iso
Download the ISO file from here:
http://www.mediafire.com/?ueyyzfymmig
Use a new CD and this free and easy program to burn your ISO file and create your bootable CD:
Here are some instructions for ImgBurn:
http://forum.imgburn.com/index.php?showtopic=61
It would be a good idea to test your bootable CD on a computer that is working.
You may need to adjust the computer BIOS settings to use the CD ROM drive as the first boot device instead of the hard disk.
These adjustments are made before Windows tries to load.
If you miss it, you will have to reboot the system again.
When you boot on the CD, follow the prompts:
Press any key to boot from CD...
The Windows Setup... will proceed.
Press 'R' to enter the Recovery Console.
Select the installation you want to access (usually 1: C:\WINDOWS)
You may be asked to enter the Administrator password (usually empty).
You should be in the C:\WINDOWS folder.
This is the same as the
C:\WINDOWS folder you see in explorer.
The Recovery Console allows basic file commands like: copy, rename, replace, delete, cd, chkdsk, fixboot, fixmbr, etc.
For a list of Recovery Console commands, enter help at the prompt or read about the XP Recovery Console here:
hope this helps
