Hi.Id check the solenids and pumps. Most likely to be a pump. Their positioned under the water tank. Full disassembly of the machine panels, a must. They slide out when your there. dazza
Hi I should have mention that a thermal sensor on one of the themoblocks maybe faulty or even could be a thermoblock element. Unless you know what your doing, id take it to repairer. dazza
Thank you Dazza, I'll give that a try and let you know. Johnty
Hi it could be a themal sensor on the theroblock or even the themoblock elements. If you dont know what your doing, then id take it to a repairer. dazza
Dazza, we have 2 Jura's, the one with the problem is actually the Impressa Z7 Chrome, does this effect your advise and if so, what should I do?
