mine did the same thing im not sure if its the same situation mine had but it was right after a storm and the brick got fried thats the box thing on the power cord u just have to pick up a new one they are only $20 for a new one, i hope this was handy to someone :Dmine did the same thing im not sure if its the same situation mine had but it was right after a storm and the brick got fried thats the box thing on the power cord u just have to pick up a new one they are only $20 for a new one, i hope this was handy to someone :D
You can't post conmments that contain an email address.
What is the source of the TV signal? I know many monitors have a "power-saving mode" that returns the unit to standby if there is no signal coming in.
Check that the signal cables are working (try swapping cables). Make sure the source is on before turning on the TV. Press the Input button to select a different source. Make sure that the source signal is not refreshing (or synching) at a rate that is incompatible with the TV. (If your source is a PC that was previously connected to a CRT monitor, the refresh rate should be reset to 60 Hz before connecting the computer the the Pioneer 424MV.)
I hope this helps.
Cindy Wells (Pioneer TVs usually give a blink code if there is a hardware problem that prevents it from turning on.)
Perhaps you have bad batteries? Connect it to another power source such as an AC wall outlet and use your power adapter and see if this helps. If it does not or you have already tried this then your camera may need to be serviced.
