Price Pfister 532-7PCC Marielle Pull-Out Kitchen Faucet with Matching Soap... Logo
Anonymous Posted on Oct 12, 2011
Price pfister 529-tmz - Price Pfister 532-7PCC Marielle Pull-Out Kitchen Faucet with Matching Soap...
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Oct 07, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
641
Points
How to replace flex hose
3 Related Answers
Anonymous
  • 8197 Answers
  • Posted on Feb 27, 2011
SOURCE: how do you unscrew the aerator housing from the
Look on the link below to see how to pull the aerator.
http://www.pfisterfaucets.com/www/ImageAssets/mirror/model/kitchen/hanover/han529-7t/ex-529-01.pdf
Anonymous
  • 145 Answers
  • Posted on May 23, 2010
SOURCE: i cant get the price pfister faucet out of kitchen...
There are several nuts on a faucet but I'm assuming you mean the plastic nuts that hold the faucet to the sink. They many times do jam up. To get them off you need to use a large flat head screw driver and a hammer and chisel them off. Chisel from the outside edge in toward the threads on two different sides.
Anonymous
  • 17 Answers
  • Posted on Sep 05, 2011
SOURCE: I have a Price Pfister
Not to sure I can help on this .....but some models come with a aerator removal wrench, packaged with faucet.......
1helpful
Price pfister kitchen faucet handle stuck and will not turn on. Model number... F-529-7RBY (Raya 1 handle pull-down)
Hi. Don't force the handle. There are seals and machined passage ways down below. More than likely some foreign material has lodged itself into faucet. The water will need to be shut off and the faucet will need to be cleaned, repaired or replaced. FYI: A whole house water filter or inline water filter will help. Any questions please let me know. Good Luck.
Price pfister ashfield f-529-myp
leave the screen out something is restricting the flow at the screen or take guts out of aerator and keep screen some have flow restrictors that may get clogged usually a plastic disk
1helpful
GT529-YPk faucet leaking
If this is a new installation, shut off the water supply to the faucet and dismantle to get at part number "974-074" under the handle. It probably has some debris from theinstallation caught up in that part.
The exploded diagram with that part number is here:
http://s7d1.scene7.com/is/content/Pfister/ex-529-03
If you download the document you will need to add ".pdf" to the extension as this was omitted- (it is just a computer thing)
Installing model f-529-adrs with 1 hole states to use plumbers putty but I have granite counter tops. What am I suppose to use???
You can use the plumbers putty on granite. If you do not want to you can also use some clear silicone. If you use the silicone make sure that you wipe off the exsess before it dries.
3helpful
The top fell off the faucet, doesn't this faucet have a life time warrenty
Price Pfister Marielle Kitchen Faucets Do come with a limited lifetime warranty from Price Pfister-to the original home owner. You can contact Price Pfister on line at www.pricepfister.com, call them toll free at 1-800-PFAUCET or Email. The faucets warranty can be downloaded at http://www.pricepfister.com/support/warranty.aspx.
29helpful
3answers
I can't disconnect the quick connect sprayer hose Price Pfister
HI, parts can be found from amazon (entire assembly too), take a look here: Amazon com price pfister marielle kitchen faucet parts. Wish you best of luck. Cheers
3helpful
2answers
Replacement Price Pfister sprayer/hose
I called Price-Pfister and they sent out the parts free under their warranty, plus a few dollars for postage.
Top Price Pfister Plumbing Experts
john h
Mike Cairns
Mike Cairns
Steve Pack
Steve Pack
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
