SOURCE: tone arm is hard to move
You have a bad tone arm. I have the same tables. You need to get it repaired if under warrenty. Or there is a service manaul online you can get from ebay. Service center for our tables is Panasonic.
I had the same problem on mine. But while it is in the shop they recalibarte it
SOURCE: Technics 1210 MK11 - 'Click' in tone arm movement
Your tonearm is damaged at the pivoting screw. Unfortunately, there is no easy way to fix this other than replacing your tonearm. The pivoting screw is a cone shape screw - aka conical screw - and this sits on 4 ball bearings, with a very thin piece of sheet metal which keeps the ball bearings in place. If this thin piece of metal is damaged - more than likely indented - it causes this sort of clicking sound you speak of. You will need to have the tonearm replaced, as this cannot be fixed. Or, shall I say, it will cost you more to try and fix the problem than it will to just replace the tonearm:
FIX = 3-6hrs @ $85/hr
or
REPLACE = 1hr @ $85 + $70 (tonearm)
You do the math.
Technics Tonearm can be purchased here, but this is not an easy replacement, and you could do more damage if you are not sure of what your doing. Professional repair is recommended. You can buy the part, then bring it to the service shop.
- OPTiC
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
SOURCE: Deck fades out when i bring the second deck in (records I mean)
are you running phono pre amps ? are you running pre amps to each deck or one for both decks , if you are running pre amps maybe the power supply is not sufficient to run two decks anymore [ possibly damaged ] but it sounds like a power delivery failure to me . hope this helps
SOURCE: muffled sound
HELLO!
I don't think the problem is the actual stylus (needle), it sounds like the magnetic cartridge has become faulty in some way (it does happen). My advice is try another cartridge and stylus (borrow if you can). If the audio stays the same then it MAY be the wiring in the arm going through the plinth (deck) and these wires terminate to pins or a small pcb board in the turntable where the phono cables and arm wires are connected. There may be a bad connection inside.
Also, make sure your tonearm counterweight and anti-skate are set up properly as well as this can have an effect on audio.
I hope this helps as I have been into audio since I was a kid!
SOURCE: Sears Tape deck/Turn table skipping!
Hi the pennies will mess up the stylus. There should be an anti skate setting at the back of the turn table, a round adjustable bit with numbers, increase the anti skate and then use the balance weigth (weight right at the back of the arm that turns to get the weight right. Set the anti skate with the tone arm light, then increase the weight a bit. Hope that helps
When was the last time you replaced our stylus? Natural wear and tear will cause such actions to take place.
