Acu-Rite Acurite Wireless Weather Thermometer 604 Logo
Anonymous Posted on Oct 12, 2011
Manual for acurite ik634160 weather station - Acu-Rite Acurite Wireless Weather Thermometer 604
electronic & computer repair& servicre
Level 3:
  • Master 12,061 Answers
  • Posted on Oct 12, 2011
Master
Level 3:
Answers
12061
Questions
0
Helped
4007071
Points
36390
AcuRite Remote Sensor 00605TX for Acu-Rite 75321A1 Weather Station. I can't get my 00605TX to reset.
Question edited for a LOT more clarity. full 'make model (what it is)'.
Question moved from Computers to Model category.
Remove the batteries from both indoor and outdoor unit. Leave them out for 10 minutes. Replace the outdoor sensor with a new battery (2xAA), and then new batteries in the main unit (3xAA).
00605 Wireless Weather Station + Companion Instructions
AcuRite https://www.acurite.com > media > manuals > 0... PDF NOTE: When replacing the batteries for the wireless sensor, remove the batteries from the sensor and clear that sensor's channel on the main unit by pressing ...
6 pages
Hard Reset for Sensor Models 00606TX/06009RMA1 & ...
AcuRite https://support.acurite.com > en-us > articles > 360007...
The following reset steps can be performed to correct issues of the sensor not connecting to the display. Symptoms of the sensor not...
https://fccid.io/RNE00605TX/User-Manual/User-Manual-707183
1helpful
AcuRite Professional Weather Center 01602BPDI. It eats the outside batteries. Batteries last about 2-3 months till low battery power shows inside with -40 degrees plus other false readings.
My National Geographic Weather Station is the opposite. The outside sensor only indicates the temperature, but the single CR2023 battery lasts a year. The inside unit on my desk lasts around 5 - 6 months and lets me know if needs a battery by showing the outside temperature as ' -- '
Although the manual says 'rechargeable batteries are not recommended', I would try 4 Sanyo Eneloop batteries. Or you could contact Acurite Support and ask them if your battery use is excessive?
01602BPDI - Professional Weather Station Instructions
AcuRite.com https://www.acurite.com > 01602-instructions
Professional Weather Center model 01602BPDI. Questions? Contact Customer Support at. (877) 221-1252 or visit www.AcuRite.com. SAVE THIS MANUAL FOR FUTURE ...
Acurite weather forcaster not showing outside temp
Here's the manual for the AcuRite Weather Forecaster. If it's not showing the outside temperature, make sure the A-B-C switch is set to match the display unit. Not doing so might be the reason it's not synchronizing and displaying the outdoor temperature. https://www.acurite.com/media/manuals/75077-75107-instructions.pdf
1helpful
2answers
Why can't I receive input from the outside sending unit?
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
I need to reset the time and do not have the instruction manual.
I Have a Acu-Rite Acurite Wireless Weather Thermometer 604RX and it came without an instructions for use. Is there any web site I can go to in order to get the instructions or could you e-mail them to me? Thanks, Pat
Top Acu-Rite Measuring Tools & Sensors Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you an Acu-Rite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
