This band you will easily get on Amazon, Ebay, Etsy and Discountedwatches247 etc. The Discountedwatches247.com provides beautiful watches and watch bands in discounted price and lots of designs and colors available. You can purchase a cute ladies watch for function, causal watch or a stylish digital watch and many more. These Cheap watches are good quality watches with the latest design and style.
to change the battery in a champion watch:
(1) remove the back, (2) carefully peel loose the foam strip and set it aside (3) release the battery retaining bracket with a needle or awl and tweezers, (4) grasp the case with your thumb and forefinger so that your thumb is holding the works inside the case, (5) turn the watch over and the battery should fall out (6) put the new battery in the holder, (7) snap the retaining bracket back in place (8) replace the foam strip (9) replace the back
You should use two extremely small flat head screw drivers to remove links on Invicta polyurethane watch bands. The smaller pens on the polyurethane watch bands have a notched cap (tiny screws) on each end .You must use one screw driver to hold the pen cap (screw) steady and the other screw driver to turn the cap (screw) counter clockwise. You only have to remove one notched cap (screw). These caps (screws) are very small and you should be careful not to lose them. Once you removed the cap (screws) you can use a small screw driver or paper clip to push the pens through the links. You should repeat this til you remove the desired links.
I know you posted this a while ago but I had the same issue and I just figured out how to solve it. You hold down on the 'Reset' button so it shows the alarm time and then while continuing to hold the 'Reset' button you press the 'Start' button right above it. Each time you press the 'Start' button, you turn the alarm and the chime every hour on and off. You know if its 'on' based on the little images on the top of the screen. The top left corner is the alarm and the bottom right is the chime.
