This will depend on your motherboard you will need to select your motherboard from a dropdown list also on the left will be types of ram ddr2 ddr3...... you will need to select which type you have If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. NON-ECC/Non-parity - Most desktop and laptop computers take NON-ECC or Non-parity memory. ECC/Parity - ECC or parity modules look for errors in data and are most often found in servers and other mission-critical applications used by large networks and businesses. Unbuffered - Most PCs and workstations use unbuffered memory which is faster than registered memory. hope this helps you
whether you can install a 4 gb module of ram
Oops,you forgot one tiny thing, what manufacturer of motherboard is it, and what Model Number? Or what computer manufacturer name is it, and what Model Number?
