2002 Ford Taurus Logo
Anonymous Posted on Oct 11, 2011
My car started missing real bad. When stopped at a traffic light or stop sign is would feel like it was going to die and would shake real bad. Yesterday it died at a traffic light. We got it home and replaced the coil pack and plug wires. Now it seems to not be getting fire on the #4 cyclinder. The engine light is on and the miss is worse than ever.
don-ohio
Level 3:
Master:
  • Ford Master 946 Answers
  • Posted on Oct 12, 2011
don-ohio
Ford Master
Level 3:
Master:
Answers
946
Questions
Helped
238966
Points
2123
Did you change the spark plugs? No chance you got one crossed up is there? don-ohio
2007 jetta stopped at a red light my car started shaking real bad then died had trouble restarting it and when restarted it is acting sluggish and wont drive
Sounds like the car started to misfire. You should have the car scanned for fault codes. An ignition coil or ignition wire set failure would cause this.
Car shakes front to back while stopped in gear
correct thinking
the car has an onboard code reporting system that stores fault codes
have the fault codes read and that will point you to the fault area
all the suggested are not correct because you say that it idles
i'm thinking a faulty brake booster or other serious vacuum leak
2answers
P0300: SOMETIMES rough idle, shake a lot OR less power above 50mph then got this code
Spark plugs in your car are good for 100,000 miles. try changing fuel filter and add a can of B&G 44K fuel additive. This stuff is the best on the market and only available at dealerships. It conditions fuel pump and injectors, also absorbs water in fuel (methanol). Try this first, your car is too new for any other problems. this should help drivability and fuel mileage. If Nissan does not have B&G, I know Toyota does. Also stay with 91 octane fuel. Check oil and coolant often. do not risk overheating in traffic, watch your gauges......
3helpful
When i'm stopped at a light or sign my cars rpm's go down and my car shakes and sometimes either acts like it wants to die or just dies
4helpful
2answers
91 Toyota Previa shaking and missing
you need to replace the fuel sock in the tank and the fuel filte and do a tuneup wires plugs and cap.
1997 Mitsubishi Galant Died
Sounds like the EGR valve is bad and is stuck in the open position.Just replace that and you should also check the catalytic converter.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
