To Enable or Disable the function key behavior,
You have customize settings in the system BIOS
Which laptop brand are you using that can help give more insight to resolution in your case
if its Dell, then reboot machine and keep tapping f2 to get into BIOS
it its HP, then reboot and keep tapping f10 key repeatedly to get into BIOS settings
Check it in BIOS and address the concerns
SOURCE: Unable to adjust the brightness of display screen
bright ness buttons are indicted witha sun like mark . they r usaly used with fn keys look for that keys
SOURCE: Print Screen Function
On the top row, on the right hand side, second from the left, there should be a Print Screen key (Print Screen / SysRq). Just press that key once - it should give you a PrintScreen.
SOURCE: "Fn" keys not working
have you reinstalled the driver the keyboard to allow you to use the special functions....
SOURCE: fn key on dell inspiron 1501 keyboard not working
Sounds like your number lock is on. Find the key with blue lettering that says 'Num Lk' (or something very similar). Press Fn and that key, and your number lock will be turned off and your keys will go back to normal.
Hope this helps.
