2003 Cadillac DeVille fuse box location
i have problem with trunck and gasoline cover doesnot open automatic , is it fuse ,how to change and where is the fues box
Kanabea is right, the only thing I might add is to look at the key you are using, or actually both keys - you might be using the VALET KEY by mistake. While there is no mistaking the VALET KEY as it's stamped right on it and is usually grey as opposed to black, it seems that the VALET locks are engaged. Check the key your using, if is says VALEY find the other key and go into the programing features and turn off the VALET mode.
I have a '99 Deville. Had the same problem. In the glove box, there are two toggles for Traction Control and Valet. Toggle the Valet one and try the remote on your key or the buttons in your dash.
For mine, someone had engaged the Valet to "ON" and locked out the remote trunk and fuel door.
Have you checked ALLDATA.COM for this info??
where is the fuse box on the drivers side located on a 1995 cadillac deville
cannot find the fuse box on the drivers side on a 1995 cadillac deville
where are the fuse boxes located?
where is the fuse boxes located
