https://www.ebay.com > ... > Phones
Find many great new & used options and get the best deals for Vintage Disney Mickey Mouse Phone Model Touch Tone Model TEIF 8000 in Wrapping at the best ...
Since you declined to specify the model of your VTech 5.8GHz phone, I can only suggest that you enter it into the search box here to download a copy of the manual. The manual will describe how to switch between pulse and tone dialing.
The Vetech phone will only support tone dialing. It does have a menu option that turns tone on or off but it still will not allow pulse dialing. I had to change the phone service from pulse dialing to tone dialing to get the phones to work. As it turned out, the phone company no longer charges extra for the tone service.
If you have the TRU9585 or the TRU9565 you may have a bad phone. If other phones work OK on the line but the unit does not, contact Uniden Customer Service at 1-800-297-1023 for help.
Have you tried unplugging your base station and all the handsets?
Sometimes the base station, where the power and the telephone line plugs into needs a reset. Just like a computer sometimes it needs a reboot.
If problem presists, take a regular analog phone and plug it in to the same jack as the cordless phone bas station, and see if it is a cable issue/ telephone company issue.
For the GE electric 2.4 GHZ phone where there is no switch, you have to press the program button and hold until it beeps (talk button will start flashing), then press the tone (star) button and program again. It will beep for confirmation
Lisa,
If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model.
TONE/PULSE DIALING
This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for
touch-tone use. To set to tone or pulse dialing:
1. Press and hold the program button for two seconds. You will hear a beep.
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
3. Press the program button again. You will hear a confirmation tone.
