Zebra DS6707 Bar Code Reader Barcode Scanners (DS6707-DC20007ZZR) Engine only Logo
Anonymous Posted on Oct 11, 2011
I need to send trigger command through RS232 interface to Symbol DS6707 barcode scanner. Please help
5 Related Answers
Anonymous
  • 432 Answers
  • Posted on Jun 22, 2007
SOURCE: Symbol LS4007I Manual not Found
http://support.symbol.com/support/searchEntry.do?languages=&rwTarget=%2FrfPlayerWidget.do&searchMode=GuidedSearch&searchString=&productLine=SG_BARCODESCANNERS_1_1&product=SG_LS_4005_1_2&document=DT_PRODUCTMANUALS_1_1&cmd=search&productFamily=&contextType=gs I'll keep trying to find the right one. Ray
Andrew Kowalski
  • 65 Answers
  • Posted on Oct 21, 2009
SOURCE: DS6608 scans encrypted barcode triggers print
You need to program the scanner through 123 sofware or by scanning specific barcodes. I can provide you with either or need. You can always contact me directly [email protected] or 630-622-2024 toll free 866-271-9891 Ask for Andrew
Anonymous
  • 32 Answers
  • Posted on Oct 27, 2009
SOURCE: Can't connect the Zebra 105SL printer through RS232 port.
And, once you have the null modem adapter or cable, you need to make sure the serial settings on the printer match your port settings on the PC.
Anonymous
  • 185 Answers
  • Posted on Oct 29, 2009
SOURCE: I'm inputing ASCII via RS232 would like barcode printout
You will need to send the data using ZPL or the printer won't recognize it , if you don't have experience in this area print through the Zebra Print Driver should work. In your application use Barcode 128 as the font and see how it goes
Anonymous
  • 47 Answers
  • Posted on Nov 04, 2009
SOURCE: I have Symbol LS9208 barcode scanner, but I don't
You'll never be able to make the appropriate cables - and Motorola (they bought Symbol) no longer publishes schematics for cables. Contact the Motorola helpdesk at 1-800-653-5350
HI I HAVE ONE MOTOROLA SYMBOL DS6707 BARCODE READER TODAY ONE PROBLEM OCCUPIED. ANY MOBILE IMEI CODE SCAN BUT BATTERY NOT SCAN. SO PLEASE HELP ME
The EMEI Barcode and battery barcode are probably not the same length. When the scanner is set for specific length, he will accept only some barcodes.
Please check the length of the barcode. Set the scanner for two specific lengths or for any length of barcode. Try to scan again.
To set the scanner you would need programming barcodes. Those are listed in the DS6707 Reference Guide, provided at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=8397807apdf
2answers
Hi can u tell me that symbol scanner ls2208 will work on ATS
The LS2208 is a universal scanner with many supported interfaces. Please check the ATS if one of the interfaces are available. See the list below:
RS-232 IBM 468X/469X Keyboard Wedge Wand Emulation Undecoded Scanner Emulation USB Synapse Adapter
When I scan with Symbol DS6707 I normally get letter b showing up after the scanned numbers. Please help!
There is probably an rule set on the scanner from the previous user. To be sure that you are not using any old settings. I would suggest to reset it to factory settings.
Connect the scanner to your Desktop PC. Download the Reference Guide for DS6707 at the page http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=8397807apdf Scan the Barcode Set All Defaults Scan the Barcode Erase All Rules
The scanner is now in factory settings and you can configure it as you need.
1helpful
Symbol ls2000 hand scanner won't read barcodes. The laser lights up and it beeps when I scan but it takes in no data. I have tried the sets all defaults programming barcodes but all it does us make a...
If the scanner beeps just once after a scan, than he recognize the barcode and sends the data to the computer. If you dont receive any data, you are waiting for them on wrong interface. Data from USB or KeyboardWedge do come to Notepad/Word etc. The data from Serial RS232 Connection can you see only in Hyperterminal or similar application.
2answers
Is this scanner only able to connect via USB?
HELLO,
the kit part number you have is a usb power plus kit, what you need is cable part number:
CBA-U01-S07ZAR
If you want to order one, let me know. I can be reached at 7275714159 x251
Thank you,
Kim GAnoe
1helpful
Barcode line enter problem
This is a custom setting. You will find on the user manual (and also at the bottom of the Quick Start guide) a special barcode that, when scanned, toggles between "CR after barcode" and "No CR after barcode".
Scanner doesn't turn on
Hello Loverboy,
the scanner turns on automatically as he he receives power from the host interface.
Please check the cables and connection. For RS232 interface would you need an external power supply. USB can power the scanner without external power supply. By Keyboard Wedge installation please connnect also the Keyboard.
Set up for Symbol LS5000
Hello Fenandez,
there is no driver needed. Just select the programming barcode for the interface (RS232, Synapse,Wand) you want to use on your host device. You would need just the Reference Guide with the barcodes.
Top Zebra Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
