Question about La Crosse Measuring Tools & Sensors
Outside temperature doens't function for a model 9N5
How reset time zone on La Crosse 9N5
The La Crosse units I am familiar with have a switch on the rear for selecting time zone.
Nov 10, 2016 | Home
Why isn't it heating?
Because its an air conditioner, not a heater?
May 03, 2015 | Heating & Cooling
MY KEYBOADS DOEN'T FUNCTION,WHAT CANI DO?
Depending of course on your full model number, you may need to replace the membrane keypad or the control panel frame assembly, which comes with a new keypad.
There's a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 26, 2012 | GE Profile : JVM3670BFBB 36" Over the...
Why doesn't my heating and cooling system come on when i start the car?
If this is a new problem, a temperature sensor may have gone bad. But if this is a new car to you, some Climate Control cars work this way.
Some will allow for Vent or Panel just to get air circulating, but the A/C should come on when you select A/C unless the outside temperature is too low.
For heater functions, the engine must warm up enough to provide heat. The Climate Control models will not turn on until it compares your temperature settings with how hot the engine water temperature is to provide this heat for you.
Now you may need to check the Antifreeze levels and check the temperature of the Radiator water to know if the Thermostat is working properly.
Oct 16, 2012 | 2001 Oldsmobile Intrigue
C Tech Weather Station. How do i reset the outside temperature. Meter says it's off?
Is the outside unit LED on? I replaced the battery on the outside unit and in doing this reset the outside information.
Jul 05, 2012 | Coghlan's CTech Wireless Weather Station...
My temp. gauge will not move.
Either it doens't work or your temperature sensor is bad. I would guess that your sensor is bad.
Dec 31, 2011 | 1994 Mercury Tracer
97 chevy lumina are there coolant fan sensors
This year doen't use a separate sensor for the cooling fans, it uses the ECT (engine coolant temp sensor) sensor that monitors engine temperature for the fuel control system, the computer turns the fans (via a relay) on when the engine reaches about 225-230 Degrees F
Oct 11, 2011 | 1997 Chevrolet Lumina
Measuring Tools & Sensors Logo
64 people viewed this question
Top La Crosse Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
