To program the remote, press and hold the component key (TV, for example) that you want to program. Then when the On-Off light turns on and stays on, enter the first code for the device you want to the remote to control. Then release the component key and check if the code controls your device. (Some codes may only control some functions so try all the keys you will want to use before deciding that you have a good code.) If the code doesn't work, repeat the steps from holding the component key.
Panasonic TV codes to try 1003, 1054, 1055, 1062, 1109, 1130, 1170, 1248 .
The RCR212W manual is available here: http://www.voxxsupport.com/images/User%20Manuals%20-%20FAQ%27s/RCR312W_DOC_OM.pdf .
Please note that if your TV is newer than your remote, you may need a new universal remote. The codes in the remote are limited to those for devices released 6 months or more before the remote was programmed.
I hope this helps.
