The CLOCK pad is used to set the clock. The clock may beset for 12 or 24 hour time of day operation. The clock has beenpreset at the factory for the 12 hour operation. When the range isfirst plugged in, or when the power supply to the range has beeninterrupted, the timer in the display will flash with power failure "PF"
Instructions:
To set the clock (example below for 1:30):1. Press the round "CLOCK" button. "CLO" will appear in the display (Fig. 2).2. Press the round "1" "3" "0" pads to set the time of day to 1:30 (Fig. 3)."CLO" will appear in the display. Press the round "Start" button. "CLO" willdisappear and the clock will start (Fig. 4).
Thank you for your inquiry, Lucie!
From what you have described your Frigidaire oven lock is stuck open and you are receiving error codes "F9" and "DR". The "F9" error code stands for runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. The "DR" code means that the door is not closed or the door latch is not recognizing the door is closed. This could be an issue with your door latch or control panel. If the reset does not help correct your issues I would recommend having a professional technician out to perform a proper diagnosis and repair. Best of luck! -Matt
Good Morning friend, thank you for your post!
I understand that your Frigidaire range is not allowing you to cancel and you are unable to use the oven. I would suggest holding down the "Cancel/Clear" button for ten seconds and that should cancel the self-cleaning. If that does not work I would recommend a reset on your range, you can do that by flipping off the household circuit breaker for ten minutes. I hope this has been helpful. -Matt
Hello Brian Pelletier, thanks for your inquiry!
I understand that you are having issues with your door not locking upon using the self-clean feature. It sounds like a possible issue with your EOC (Electronic Oven Control) or dock latch assembly. I would suggest unplugging your range if possible or flipping you breaker for ten minutes to perform reset. If the light continues to flash you may want to seek assistance from a professional for proper diagnosis and repair. -Matt
