SOURCE: best wall mount for sylvania 6842thg plasma
Here is a link to a hanging bracket that will work for your monitor. It is a true universal hanging bracket. You wont find a better one for the price.
SOURCE: Help our sylvania 6842thg plasma
This is a common problem on Sylvania Flat Screen TVs (I have seen a lot of TV with this same problem), It is usually caused by a failure on the Power Board.
A new power board will cost about $150 - $190 USD. If you have experience on electronics repair and want to fix it by yourself, you can get the board through ebay or any online store.
A TV technician may charge about $280 - $ 400 to fix this issue (includin parts).
Read the user manual for warranty information. If the TV still under warranty, contact the manufacturer for assistance on repairs.
SOURCE: vizio 46"
Try pressin the channel up/down button instead of the input button. Sometimes this will activate bring up the cable/antenna input...
Good Luck....
SOURCE: when i connect any device to the TV whether using
You have to change the input on your TV to what jack you are plugging into. Look on your remote for an input button.
SOURCE: when you start light turns
DOES THE TV STAY ON ??DOES IT TURN OFF?...MOST CASES IS A FAILURE IN ONE OF THE POWER PROCESSING BOARDS..WHICH MEANS THAT HAS TO BE REPLACED..
