it is not a fuse. as if it shorted it may blow it and then nothing .. the sw to either one burner is at fault replace the sw 's ( both and the cook top should be ok . sw cost around 25 to 40 ea ..
you will have to remove top and find short . it sounds like a burner of melted wiring. .. also ck the swithces for dark connections as the could be the cause. mm
Water probably did get into the switch(es). The best bet for a fast fix is to pull the knobs off and use an air can (like for blowing dust out electronics) to blow down into the holes. This will dry out any water in there and should allow you to use it again. To be extra sure, blow out the switches and leave the knobs off over night. In the morning the knobs can be replaced and the cook top should be good to use. Hope this helps!
Sounds like igniter problem. Did some one pull the electrical cord or has a fuse or breaker blown/ Things to check. Your igniter is run by electricity.
