Cars & Trucks Logo
James Ward Posted on Oct 10, 2011
Wiring diagram for Weldex WDRV 3057 - Cars & Trucks
bigjohnpap
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Mar 26, 2013
bigjohnpap
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
Helped
5345
Points
39
The pin configuration for the weldex camera is as follows: (when looking at the camera plug) : upper left pin=12v+ , lower left pin=audio out , upper right pin=video out , lower right pin=ground(also common for the audio & video out.
The left rear turn signal on my 1998 Aurora will not flash. According to the Owners manual the correct lamp is a 3057. I have tried 2 new 3057 bulbs they light up but won't flash. The right turn...
Normally, it means either the front or the rear bulb is burned out. If front and rear bulbs are good, and that means both lamp filaments in both bulbs are good. It could be the flasher, a bad ground, a bad bulb socket, or the turn signal switch.
1helpful
2answers
What is the part number for a replacement bulb for a 1997 Jeep Grand Cherokee front turn signal? Front, not side!
The part # for your 1997 grand cherokee front turn signal bulb not the side is 3057, good day
What bulbs are needed to fix back tail lights
It all depent's which ones are out, here a list of rear bulb's.
Turn signal bulbs # 921
Stoplight's # 3057
Tail light's # 3057
Backup light's # 921
Center stop light # 921
License plate light # 17177
Side marker # 194
Have some one turn light on while some one check them. First light then brakes then turn signals. till you see which ones don't work, and replace as needed.
Drivers side brake light and horn won't work,,is it the multi function switch? 1999 chev blazer 4x4 . if so how much does a new one cost?
No there not connected, replace the brake light
1999 Chevrolet Blazer Auto Light Bulb Size Guide
Low Beam Headlight Bulb Size: 9006
High Beam Headlamp Light Bulb Size: 9005
Parking Light Bulb Size: 3157
Front Turn Signal Light Bulb Size: 3157
Rear Turn Signal Light Bulb Size: 3057
Tail Light Bulb Size: 3057
Stop Light Bulb Size: 3057
High Mount Stop Light Bulb Size: Assembly
Fog/Driving Light Bulb Size: 880 or 881
License Plate Light Bulb Size: 194
Back Up Light Bulb Size: 3156
Front Sidemarker Light Bulb Size: 194
Ash Tray Light Bulb Size: 161
Glove Box Light Bulb Size: 194
Map Light Bulb Size: 168 or 211-2
Step/Courtesy Light Bulb Size: 168 or 211-2
Trunk/Cargo Area Light Bulb Size: 211-2
Under Hood Light Bulb Size: 93
Instrument-General Light Bulb Size: 161 or 37 or PC194 or PC74
Check Engine Indicator Light Bulb Size: PC74
Hi-Beam Indicator Light Bulb Size: PC74
Seat Belt Indicator Light Bulb Size: PC194
Brake Warning Light Bulb Size: PC74
Automatic Transmission Indicator Light Bulb Size: 194
Directional Signal Indicator Light Bulb Size: PC74
As for the horn, inspect the fuse and relay and most common it would be a bad ground wire or worst a bad horn due to corrosion. Horn will be located in the drivers side fender.
Thank you for using fixya.
1helpful
2000 pontiac montana. I want to replace the driving ligh bulbs. the under the headlights what size is it?
Here is the rest of the bulb size used in your Montana.
2000 Pontiac Montana Auto Light Bulb Diagram
Low Beam Headlight Bulb Size: 9004
High Beam Headlamp Light Bulb Size: 9004
Parking Light Bulb Size: 4157NALL
Front Turn Signal Light Bulb Size: 4157NALL
Rear Turn Signal Light Bulb Size: 3156
License Plate Light Bulb Size: 168
Ash Tray Light Bulb Size: 558
Dome Light Bulb Size: 562
Trunk/Cargo Area Light Bulb Size: 212-2
Daytime Running Light Bulb Size: 3157NALL
Which bulb is for the taillamp/stoplamp/turn siganl lampand which fuse ?? 2005
2005 CHEVROLET Malibu
Low beam headlamp
H11
High beam headlamp
H9
Parking light
3157
Front turn signal
3157
Rear turn signal
3057
Tail light
3057
Stop light
3057
High mount stop light
912
Fog/Driving light
880
License plate
194
Back up light
921
Front sidemarker
24
Rear sidemarker
194
Ash tray
161
Glove box
194
Map light
168
Dome light
561
Step/Courtesy light
168
37
Trunk/Cargo area
211-2
http://www.sylvania.com/ConsumerProducts/AutomotiveLighting/LampReplacementGuide/AutoLRG-Results.htm
You can find all auto bulb info here.As far as the fuse there should be a fuse diagrahm on the back of the access door.Well hope this helps.
3answers
2000 Alero
3157
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_00678fd4800d19c5
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
