Question about RIM BlackBerry Pearl 8100
Is the faceplate of blackberry pearl 9105 glued and therefore can by removed by prying it open with a pry tool? no need to unscrew any screw? The faceplate I am talking about is the external lens. I just ordered from amazon.com a replacement and I want to be sure on how I will remove the scratched one and install the new one.
3 Suggested Answers
SOURCE:
celltech_adv
  • 443 Answers
SOURCE: how do I replace the clear plastic screen cover of
It should only be stuck on there with some tape. It's tricky but it can come off. Then when ya get the new one. There will be a plastic cover over the adhesive you'll remove, and stick right back on the phone
Posted on Oct 10, 2011
celltech_adv
  • 443 Answers
SOURCE: how do i change the faceplate of my blackberry
Take the back off, take the battery out, then gently remove the hex screws, and the faceplate should come right off, no problems
How do I disassemble it to replace the battery?
usually starts with screws on bottom of shaver where power cord is plugged in. most shavers have soldered in batteries, not an easy replacement.
Jul 20, 2015 | Remington MicroScreen DA-307 Electric...
Please help me how to unlock and please give me the network unlocking code for blackberry pearl 9105? my phone is locked in SUNCELLULAR network here in the Philippines. my IMEI number is 351974.04.500621.1...
There can be many ways to Unlock your phone.As far as i know unlocking by codes is the simple and safe way.You will need the unique MEP Code for your Blackberry and to get it you can use a website with service for Blackberry unlocking .so you can use a website to Unlock your Blackberry Pearl 9105
online instantly - OR local mobile shop .they are mostly using cables to unlock it and the price is higher then on unlocking websites but the result is the same: SIM free Blackberry.
Oct 18, 2011 | RIM BlackBerry Pearl 8100
How do I replace the clear plastic screen cover of my blackberry pearl 9105? Can I just pry it open or do I have to remove some screws?
Oct 04, 2011 | RIM BlackBerry Pearl 8100
How do i change the faceplate of my blackberry pearl 9105?
How to disassemble altec lansing 220 speaker
See if the front cover can be lifted by carefully prying. The speakers may be mounted by screws - remove the screws.
Dec 13, 2010 | Altec Lansing 220 Computer Speakers
Blackberry pearl
Cellfixers.com I recommend ordering the T-6 driver with the pry tool. The video on FixYa was a life saver. I also found a slideshow with still pics. Good luck!
Jun 26, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
Blackberry 8700g screen lens replacement directions needed
Hi.....don't know if you have already resolved this problem, but if not, you can view this video on you tube which shows you exactly how to do it. This doesn't say 8330 but still applies same as the others.  BlackBerry 8300 8310 8320 lens replacement proceedure
Apr 19, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Need to replace keypad on Blackberry Pearl 8130
Hi Keith,
if you have knowledge of how the phone disassembles you can remove the screws in the back
and open the phone by using a razor bladed and popping the plastic lockes around the edge
Check out this youtube tutorial before you do anything. if you feel ok to do it, it's you phone.
But be warned the plastic is delicate so be sure you have patience and work slow.Hope this helps, if so leave a FIXYA Vote
Mar 30, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
Blackberry got damp in rainstorm and buttons won't work
Moisture has caused a little short in between the contact under th keyboard.
I would recommend to open your phone and gently wipe any moisture under the keyboard..
1) Remove Battery
2) Remove 2 #6 torque screw from rear top of phone
3) Using a prying tool remove base of phone ( where the log of the phone company is
4) Remove 2 more #6 torque screws
5) Remove side chrome cover ( Snaps on)
6) Lever in between front and rear case and pry open gently
7) Wipe gently and re-mount in reverse order..
It should work
Sep 03, 2008 | RIM BlackBerry Pearl 8100
Putting on faceplate for samsung t319
hi you best bet is go to a repair mobile shop if are in doubt to try this .
you'll need a small Philips head screwdriver to complete the installation. To take off original faceplate, remove 2 screws located below the inside display (screws are hidden under stickers). Next, gently pry off the faceplate along the edges between faceplate and phone with a Faceplate Removal Pry Tool. When re-attaching screws, do not over-tighten screws
riz.
Aug 23, 2007 | Nokia 6288 Cellular Phone
RIM BlackBerry  Pearl  8100 Logo
49 people viewed this question
Top RIM Computers & Internet Experts
Otman Lahlou
Otman Lahlou
Vincent G
Vincent G
ChrisChris70
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
