SOURCE: first time charging up of archos 5.just the green
Your archos probably has a glitch in it. You might have to do a system recovery of it. First download the latest firmware program from Archos website. Here is a quick possible fix when the screen comes up reset the archos by inserting a paperclip in the reset hole located at the bottom of the unit right of the connectors it might work it might not. if that doesn't fix the problem do a hard reset when the logo screen comes up hold down the volume+ button until the white recovery page comes up. First try repairing the unit if that doesn't work try format and follow the instructions. the touch screen doesn't function during the recovery page so use the volume+&- buttons & power button. When you get done your archos should be set to factory presets so you have to set it up. Good Luck
SOURCE: first time charging up of archos 5,it has now been
@wilkerwkocer
On an Archos, battery is fully charge when the CHG LED light is flashing, while that light is ON all the time, the unit is still charging.
Now, in order to charge your Archos you must leave it on Suspended mode, by holding the Power button for about 4-5 seconds until it says "Suspending", DO NOT leave it on completely "Shutdown" mode, or your battery will never charge, and you are also risking the life of your battery by doing so.
So in other words:
1) On a PC via USB it should take around 8 hours to charge, while connected to an Archos mini dock, battery dock, or DVR Station, it should take around 3 hours to fully charge.
2) Leave your unit completely "Shutdown" (hold the Power button and wait 10 secs. or so until it says "Shutting down" and let it go off.
3) Connect it to your power source, either USB on computer, or external charging device as mentioned above, it will come back on, the two LED lights CHG and Power will come on, leave it like that, and after a few minutes the unit will go into Standby/Suspended mode by itself, and there is when you are charging your battery the right way.
3) Wait 8 hours if connected to your PC, or 3 hours if connected to an external power supply (as described above). If still after being in suspended mode (not completely off) your CHG light isn't blinking after the 8 hours on PC, 3 hours on external power supply, then suspect your battery is defective.
In that case, if the unit is still under warranty contact Archos, if it is out of warranty. If it isn't under warranty, you can buy a replacement battery on eBay and either replace it yourself, or find someone with the technical skill to do it for you.
I hope this helped you.
SOURCE: Archos 5 not working, will not switch on.
Hi I would think the best place to start is with ARCHOS,
give them the lowdown and see what they come up with.
You could use the Archos forum and look through the help files
