Hi i am very electronics orinted. My tv was a unfortunate ivctim of flooding here. Now even though it was dried out very well it is stuck in stnadby mode... It will get the statiuc branng of the tube firing up for a second, but no display, the tv is stuck in standby mode. Does anybody know Where i can find rebuilt or new chassis for this tv????? Or where to send it for repairs?
SOURCE: Sony TV stuck in stand by mode
Yes. The 9 blinks indiate a problem in the power supply area. I need to look up your specific model later today to get you the specific parts. If you are comfortable with soldering and working inside the set, you should be able to repair this yourself.
Stay tuned...
Dan
SOURCE: stuck in standby
The 4 blinks indicate a vertical deflection problem. Either the connections on the legs of the vertical IC are bad or the IC is defective. If you can solder, you can fix this yourself. Let me know if you wish to attempt the repair and I'll provide more details and instructions.
Dan
SOURCE: Red stand by light blinking
5 blinks = lamp driver (ballast) failure.
1-468-798-14 for the 610 model
replacement is done from the back of the set, should be straight forward, keep the red ballast wires apart for best results
if a tech replaced the red tube, you have an older tv where 5 blinks is the AKB error meaning your CRTs are getting old.
SOURCE: Dmtech TV is stuck in stanby mode
The problem IS PROBABLY BEING CAUSED BY A SHORTED POWER REGULATOR (MX084 ) OR AN OPEN FUSEABLE RESISTOR IN THE POPWER SUPPLY...
thank u rate me!!
does any 1 know how to fix my problem tv is stuck on standby
