Question about HP Office Equipment & Supplies
Adf does not work properly in hp laserjet m1536dnf ,in fact nevefr stop and pick up paper for ever!!!!
  • HP Master
  • 228 Answers
JUst like someone already said, just clean the rollers. Here's a video of similar HP ADF unit.
Posted on Feb 04, 2019
Hello
hp laser jet m1536dnf adf miss pickup
solution is change flat ribbon cable between adf to printer main board .
sen
Posted on Jul 19, 2013
ctf1800
  • 4402 Answers
SOURCE: ADF for MP530 does not work
1. Press ON/OFF switch to reset the multifunction device 2. Press Stop/Reset and ON/OFF to reset the printer 3. The MP530 may require repair
Posted on Feb 04, 2008
SOURCE: Laserjet 1320 will not pick paper
A small plastic 'key' on the end of the paper pickup drive shaft has been known to break off. You will know if this has happened if the paper feed roller rotates freely.
Posted on Nov 05, 2008
  • 95 Answers
SOURCE: HP laserjet 3380 ADF
It sounds like the rollers need to be cleaned in your ADF. Please make sure there isn't any torn paper or labels in the path of the ADF. Try qtips and some water to clean rollers. If you have roller cleaner that would be great or 91% alcohol but be very careful with the alcohol. DO NOT use anything below 91% because it can cause damage to the rollers. If this does not work you will need to replace the rollers in the ADF. Good luck.
Posted on Feb 12, 2008
Scott Ellin
  • 558 Answers
SOURCE: hp laserjet 1200 paper jam
Please Follow the instructions in an attempt to resolve the issue you are facing:
  • Turn off the printer and remove all paper from the paper tray & disconnect it from the computer.
  • With the printer off, check for any obstructions such as torn paper or foreign objects.
  • Turn on the printer (still disconnected from the computer) and check the lights / lcd screen.
Still getting the same error ? Go for Warranty or Service.
Else,
  • Place 20-30 sheets of paper in the printer, ensuring none of the paper is torn or creased.
  • Make sure that the paper is flush with the far right edge of paper tray, move the left edge paper guide over so that it touches the left side of the paper.
  • Try to feed paper manually (using the paper feed button).
If you still get the error let me know for further troubleshooting,
Dont vote till you find it is Helpful or FixYa.
Thanks,
Scott
Posted on Nov 14, 2008
SOURCE: Have a hp laserjet 4l paper jam problem.No paper
I have had a similar problem. The 4L has an inherent fault in the motor drive gear. It is made of nylon and has probably developed a hair line crack. As a result the gear slips when the printer starts up and tries to feed paper. I have replaced this part some years ago by replacing the whole motor and gear. I did find the replacement parts on eBay today. Here's the url:
http://stores.shop.ebay.com/Laserprinterkits-Printer-Repair__W0QQ_armrsZ1QQ_fsubZ4
The manual is also on line at another place. But when you order the parts you get a manual on CD. I am not the guy selling the parts but need them too that's how I found them.
Good luck.
Posted on Jun 07, 2009
Hp laserjet 1536 dnf MFP. How can I repair document feeder?
how to fix and repair the adf doc feeder Q5997A hp laserjet ...
? 1:36
https://www.youtube.com/watch?v=lpTj4jiLaY8
Dec 12, 2011 - Uploaded by BrokenPrinter1
Parts Available @ BrokenPrinter.com how to fix and replace the rollers on a hp laserjet 4345 mfp and color ...
Fixing Paper Pick-Up Issues - HP LaserJet Pro M1212nf ...
? 5:40
https://www.youtube.com/watch?v=ZXtAhSDYqyU
Jan 23, 2013 - Uploaded by HP Printer Support
Learn what to do if your HP printer does not pick up or feed paper from the ADF when you do have paper loaded, and a Doc feedermispick error message display... ... FIX YOUR PRINTER: ERROR: Printer Does not Grab Paper fromTray ... Kit m3027 mfp- Kit Hp m3027 mfp - Kit Mantenimiento m3027 mfp ...
'Document feeder mispick' Message Displays on the Control ...
Dec 13, 2015 | HP Office Equipment & Supplies
Amber light on no panel error code ADF stops working.
there a small pieces of paper in the paper path of the ADF by the paper jam sensor.
Nov 12, 2013 | HP LaserJet 4730mfp All-In-One Printer
Doc feeder jam error on HP laserjet M1522nf continuesly also due to that i am unable to scan and also its showing that "Device is busy try again later"
Open adf cover, remove adf pick up unit, two sensor located in it 1. paper leading edge sensor, located upper portion of the unit.2. paper out sensor located back side of the adf pick up unit. Carefully open this unit your will easily find out the sensor location..
Sep 13, 2011 | HP LaserJet M1522nf Multifunction Printer...
HP Officejet Pro LP 7880 feeder does not work, how to fix it?
Step one: Check the paper in the ADF The condition of the paper or the amount of paper loaded in the ADF might prevent the ADF from picking it up and feeding it through the product.
  1. Make sure that no more than 50 sheets of paper are in the ADF input tray.
  2. Make sure the original is not photo paper or carbon paper. These types of originals must be loaded on the scanner glass.
  3. Make sure the original document that is loaded in the ADF meets the following criteria:
    • Free from curls, folds, creases, and tears
    • Does not have staples or clips attached
Step two: Make sure the ADF pick assembly is in good working condition
  1. Remove the document feeder and open the ADF cover.
  2. While lifting the blue-green lever, carefully rotate the pick assembly toward the open ADF cover until it stops.
  3. Examine the pick assembly.
    • Make sure the bottom roller is held firmly in place by the two-catch, which is located to the left and the right of the roller.
    • Make sure the stack stopper, which is located between the top and bottom rollers, fits within the double slots just above the bottom roller. The stack stopper should move freely within the double slots to flow up and down when the whole pick assembly is lifted and lowered into position.
  4. Return the pick assembly to its original position.
  5. When the product is turned on, the top roller will reset to its original position above the separator pad. There will be a gap between the separator pad and the top roller.
  6. If there is no gap between the ADF top roller and the separator pad, press the Power button to turn off the product.
  7. Wait three to five seconds and then press the Power button to turn the product on. The ADF rollers should reset to the correct positions.
  8. Close the ADF cover and replace the document feeder.
Step three: Clean the rollers and separator pad
  3. Lightly dampen a clean, lint-free cloth with distilled water, and then squeeze any excess liquid from it.
  4. Use the damp cloth to wipe any residue off the rollers and the separator pad. If the residue does not come off using distilled water, use isopropyl (rubbing) alcohol on the cloth instead.
  5. Return the pick assembly to its original position.
  6. Close the ADF cover and replace the document feeder.
Step four: Detaching and re-attaching the ADF pick roller assembly If the ADF pick assembly is detached or not connected properly, follow the steps below to resolve the issue. If the ADF pick assembly works well, do not perform these steps.
  1. Press the Power button to turn off the All-in-One.
  2. Remove the document feeder and open the ADF cover.
  3. Press the blue-green ADF-release button to release the ADF rollers from the pick assembly as shown in the figure below (the red arrow is pointing to the ADF release button).
  4. Re-attach the ADF pick rollers by placing the rollers into the roller slot of the ADF pick assembly as shown in the figure below. The red arrows show the gears on the ADF pick assembly aligned on one side. The yellow arrows point to the two-catch notch.
  5. Once the rollers are placed on the two-catch notch, push them in, so that the two-catch clicks into place. The photo below shows a correctly installed ADF pick assembly.
  6. Close the ADF assembly and cover.
  7. Turn the product on and make a copy with the ADF to check that the pick assembly works.
Jul 16, 2010 | HP Officejet Pro L7680 All-In-One Printer
HP laserjet 3030 ADF will not work on copying
clean the paper pick up rollers on the ADF using Rubber Rejuvenator spray.
Mar 09, 2010 | HP LaserJet 3030 All-In-One Printer
I HAVE HP cm1312nfiMFP all in one printer. The
Are the ADF rollers turning without picking paper, or is it just not running at all? If the former, check the ADF rollers. If they are smooth, then they are worn and need to be replaced. if the latter, check your driver settings. If they are pointing to the ADF, try removing and reloading your print drivers.
Jan 13, 2010 | HP LaserJet 5000gn Printer
Our HP laserjet M2727nf does not feed the paper to print anything
just clean paper pick up roller whit wet cloth or alcohol...you can do this for ADF pick up rollers too if someday have the same problem whit ADF. Good Luck!
Oct 05, 2009 | HP Laserjet M2727nf Multifunction Printer
When trying to copy papers do not feed but if you scan they will
HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
  • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
  2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
  3. Close the ADF cover plate.
  • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
  1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
  2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
  3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
  4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
  5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
  6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
  7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
  9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
Have a good day
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
I NEED TO KNOW WHERE I CAN ORDER AN ADF PICKUP ROLLER ASSEMBLY
No problem, I had the same problem with a printer. Check this out, not too expensive either.
http://www.printersupplies.com/p-Q3948-67904~PaperJamKits.html
Feb 10, 2009 | HP LaserJet 2840 Printer
Doc.feder jam
Try cleaning the rollers in the ADF (Automatic Document Feeder).
It might temporarily solve the problem, but rollers do have a limited life time, so you will eventually need new ones.
Part info:
5851-3580 - Automatic document feeder (ADF) paper pick-up roller assembly
Price: $15.57
Dec 10, 2008 | HP LaserJet 3055 All-In-One Printer
2,916 people viewed this question
Clive
Clive
