Mackie SRM-450 System Logo
Anonymous Posted on Oct 09, 2011
How to make speaker heavy stereo sound - Mackie SRM-450 System
Power Electronics
Level 2:
Champion:
  • Expert 243 Answers
  • Posted on Nov 08, 2013
Power Electronics
Expert
Level 2:
Champion:
Answers
243
Questions
Helped
61620
Points
270
You certainly will need at least two units and a stereo mixer or stereo audio source.
Color codes for my jensen eqa 111. And I'm hoping the side with the rca's is the "Out" side
Contact Jenson direct. They are a great company. There is nothing online
Jensenmobile Mobile Audio, Multimedia, Receivers, Speakers ...
jensenmobile.com
Mobile audio performance upgrades for cars and trucks. Multimedia, Receivers ... Multimedia - Jensen Electronics ... Amplifier. Speakers - Jensen Electronics ... ‎Product Categories · ‎Support · ‎Contact Us · ‎Multimedia
ASA - Jensen
www.jensen-electronics.com
JENSEN Heavy Duty develops stereos, speakers, amplifiers, and sound systems ... Component video input x 1 (YPbPr); Stereo audio input x 1; HDMI input x 2 ...
4answers
Maudio 192 output
You need the plug/cable that inputs to your mixing desk and outputs from your sound card.
I have a 2000 oldsmobile alero and I can't get sound out of my rear speakers good speakers and connection just no sound
OLDSMOBILE ALERO 2000 speakers - Sonic Electronix
www.sonicelectronix.com/oldsmobile-alero-2000-car-speakers.html
OLDSMOBILE ALERO 2000 speakers - find speakers that fit your ... sound. This size is capable of delivering exceptional mid-bass that can't be found in smaller ...
2001 Oldsmobile Alero Car Radio Stereo Audio Wiring ...
www.modifiedlife.com/2001-oldsmobile-alero-car-radio-stereo-audio-wi...
Easy Plug and Play Wiring Adapter. ... 2001 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram ... If you can't find your car audio wire diagram, car stereo wire diagram or car radio ... Right Rear Speaker Positive Wire (+): Dark Blue ... olds alero and I have replace the stock stereo and have found that the sound out put ...
Request a Oldsmobile Car Radio Stereo Wiring Diagram
Downloaded music on sd card but can"t get it to play
Do you get normal sound other than that downloaded music? If so you may need to change the format the music is in. Do an internet search for "How to change the format on an audio file". What program you will need to use depends on the format the original is in.
One of my Bose 601 speakers has developed a mid freq buzzing at volume. Ant ideas?
Yep, if it is a scratchy sort of sound, the units coil has overheated, the voice coils insulation has bubbled and expanded, and is now rubbing against the magnet as it moves. Only fix is to replace the driver. U can confirm by moving the inner circle of the cone in and out of the magnet. Should not rub and be perfectly centered around the magnet.
A vibration sort of sound can be caused by loose screws holding down the driver. But that is usually the case on your large heavy drivers with large excursions, not a mid range speaker.
Sound went out in the stereo i was driving and the sound went out in my stock stereo in my 2007 cobalt. the fuses are ok, the stereo light is on. theres just no sound. what can i do?
You might want to check and see if you have somehow lost connection to your speakers. Not familiar with vehicle but I do know stereo's, if the light is on on the Stereo then it should be OK. Check under the dash and around and see if something has come loose going to your speakers. Caution~ DO NOT try to touch another speaker to an existing speaker because if not done properly it will change the speaker resistance and result in a burnt out channel in your stereo.
Gillight
How do i hook up Altec Lansing AVS500 speakers to my computer
Hello sweetnikki1,
The Altec Lansing AVS500 are 4.1 channel speakers, meaning 4 speakers (front, rear and 2 satellites) and a subwoofer.
1. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the satellite cords are similarly color coded. The output from the sub to the front right satellite is a heavy-duty cable that immediately stands out from the rest. This cable is thicker because the right front speaker has most of the system controls on it: power, volume, and surround volume. If you do not have a surround sound card, make sure you obtain the proper adapter or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, on the left side are the sub level control, the AC jack, satellite outs, and a sound mode switch. With this switch you decide between Gaming and Stereo. In Stereo mode, the normal stereo signal is sent to both the fronts and the rears. In Gaming mode, the speakers use the four-channel signal from your soundcard. Hence if you just hav the regular sound card, do not connect the satellite speakers and use Stereo mode.
3. You can also use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
Hope this helps..
Should you have any further questions, please feel free to post them here. Please do not assign a rating until you feel your problem is resolved. I will try my best to help you further, if need be.
If you are satisfied with my solution or have no other questions, please close the problem by assigning a FixYa! rating for my solution. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Eric
ADMIN Eric
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
