The first thing to do is clean the disk.
Hold the disk by the outer edge (side with writing on it should face towards the floor) and make sure your fingers don't touch the clear part of the disk.
Dampen a soft cloth that will not scratch the surface (microfiber cleaning cloths work best). Starting from the center of the disk, wipe in a straight line to the outer edge. Do not rub in circular motions. Repeat until entire surface has been cleaned.
Insert the disk into the console. If it still doesn't work, your lens may need to be cleaned. I'd recommend taking your console to a local gaming or tech store. A qualified technician will be able to clean the console without causing damage.
Hope this helped,
-Dan
SOURCE: My Fifa 08 disc is saying unreadable
This is very common with many games. If there is nothing wrong with your disc, xbox.com will suggest two possibilities:
1: the hard drive is messed up. If you do not have this problem with no hard drive/ different memory hard drive you must erase your hard drive and start over.
2: the console is messed up. You'll have to send it to Xbox to get it fixed.
I'm having the same problem with many games and am going to have to fix my box or get a new one.
PS3 Freezing
If your PS3 is freezing up on games then it can
be solved just by stopping the heat. It is not that tough to fix!
Check out this post to see a full solution:
It should only take you 1
hour to fix this.
Hope this helps?
