SOURCE: Problem facing with paring Jabra BT125 bluetooth with Nokia 6300 handset
http://jabra.pairx.co.uk/?l=28&pp=608
This is the tool to pair.
Njoy,
Kailash Rele
SOURCE: jabra bt125 broken ear hook
It's kinda cheesy, but a piece of #10 wire fits perfectly into the hole. That's what I'm using now. Neither the original is very comfortable, but they work.
SOURCE: Jabra BT125 headset not connecting to Samsung F480
you have to switch the bluetooth headset to pairing mode not just swithcing it on. Hold the power on button continuously even after it switches on then the light will remain on. Then you switch on the bluetooth in the mobile and start searching for bluetooth devices. You will find your bluetooth headset in the mobile. Select it and pair. Usual code will be 0000, but it might differ check with the manual which can be found online too. This will definitely solve your problem.
SOURCE: i cant pair my jabra bt125 with my nokia n97
This is one of the mistake commonly done by many people. First you need to pair. Let me walk you through. First, the headset has to be switched to pairing mode which is done by holding the on button for a while even after the headset is switched on. Then the bluetooth headset light will remain on. You switch on the phone bluetooth, search new device. Then select it and press the option for pairing. Read the instructions which come on the phone display and select accordingly. It will ask for passcode which is usually four zeros. Then it will get paired ask you whether to connect. You select connect and you are done.
