SC 541 is a fixing unit error, clean the thermistor and then reset the code by pressing clear(yellow) then 107 and hold stop(red) key for 5 to 10 seconds then the display change. now turn off the machine from main switch, wait for five second and then turn on the machine.
this will reset the SC541. in case if the problem exist change your thermistor and check the thermostat.
Hi!!!!!
may be the was damaged
or
try to clean use dry tissue
or replaced the drum
SOURCE: error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
