Usually there are four things that affect the driver not reaching the top of cylinder. Piston oring too tight or too loose, exhaust air is restricted at top of gun , check valve oring is missing, or air leaking down thru blade seal. Assuming that the piston oring is ok and exhaust is not restricted, make sure that oring # 092235 is in place covering the small holes on the outer lower portion of the cylinder. this is the check valve that causes piston to come up. If, however, too much air leaks down past the blade seal, the driver will not make it to the top. Blade seal is a metal washer with slit just large enough to pass the driver blade. If worn, just make a washer out of tire tube and make a small cut with sharp blade just large enough to pass the driver blade. Make the washer larger than the metal washer and just place it on top of the metal washer. Put back together and nail away. Good luck
SOURCE: paslode im350 piston will not return
It sounds as if the piston o ring is worn. Does the piston drop if you just give it a slight bump with no nails in the magazine, if so that is the problem and would need replaced. Let me know otherwise and I will dig deeper
SOURCE: paslode t250 f16 leaks air from the cap difuser
The most common problem with this nailer is the plastic seal that sits on top of the cylinder. This seal (ususlly white, yellow or black in color ) will cause the nailer to leak lots of air out top of gun. Examine seal for cracks and replace as necessary; the part number is 402725 and is available at www.toolpartsdirect.com This should stop the rapid air leak. After installing the new seal, if you have a very small constant leak out top of the gun then remove the screw holding the headvalve in place and check for small scratches where the orings contact headvalve. Use very fine sandpaper (300 to 400 grit) to remove scratches. Clean and re-use the same orings using silicone grease instead of oil and re-assemble. This should stop all leaks. Silicone grease is available at Lowes lumber in the plumbing department. It is used to lube orings in faucets. If you have more questions about this gun please email, Good Luck
SOURCE: after each shot the nail gun jams
hi visit your supplier and ask for a overhaul kit once fitted your tool will be licke new
best of look ian
SOURCE: Paslode 5350/90S PM leaks air from the top
Yes it should and also check the condition of the cylinder seal and the bumper. If either is damaged it could also affect the tool. Let me know and you can also go to Paslode.com and download a breakdown and get a parts kit for this along with installation instructions.
