Cyber-shot cameras nowadays have a built-in rechargeable battery for retaining time, date, and other settings. Since the built-in rechargeable battery is not removable, current Cyber-shot camera models can only be returned to the original factory settings by pressing a small RESET button on the camera or by using an Initialize option in the menu.
Older-model Cyber-shot cameras (prior to the year 2000) do not have a built-in rechargeable battery and do not have a RESET button or Initialize option in the menu. These cameras require a manual power reset.
IMPORTANT: To determine whether or not your camera has a RESET button or Initialize option, or for other model-specific information to complete any of the steps in this solution, refer to the operating instructions supplied with the product.
Follow the appropriate procedure below for your camera. Using an Initialize option in the menu
Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button:
Locate the RESET button on the camera.
Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
After 2-3 seconds has elapsed, release the RESET button.
Performing a manual power reset:
Turn off the camera.
Remove the battery pack.
Remove the button-sized lithium battery.
Allow the camera to remain without power for 30 seconds.
Reinsert the button-sized lithium battery.
Reinsert the battery pack.
Turn on the camera.
If your camera is experiencing an issue and the issue is not resolved by performing the appropriate reset procedure above, then service may be required.
Hope this helps.
Error: TURN
THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens
Mechanism is stuck or when affected by any malfunction. If turning the power on
and off again does not resolve the error message, try doing a power reset
and Initialize option.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Turn on the camera.
To reset the Camera back to factory default, select the
INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will
set the user defined settings back to factory default. The images and videos
will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
