SOURCE: jura impressa S70
its a grinder group fault , the seal on the internal group head (the part that compresses the ground before brewing) has stuck or gone dry from lack of use. if u gain access to the internal of the machine( may need a special tool, oval head srews) grease with food grade lube, the red/orange seal on the long 45 degree cylinder inside. u can manually turn the gear by hand once inside. If still a problem check the motor that drives the same unit.
SOURCE: Jura impressa x90 keeps beeping
may need descaling, if this is the case you always need to descale first
SOURCE: Jura x90 flashes message fill powder and we don't use powder
It seems to be the microswitch on powder lid that`s not locking. Check if there`s something missing from the lid, and then maybe try to put something in to close the switch.
SOURCE: Jura S9 coffee machine not drawing water - says FILL SYSTEM
I think the magnetic valve is defective. This is located on the left side (seen from behind inside the machine) and there`s connections between the thermoblock and the hot water outlet. Try to press the steambutton and check if the magnetic valve clicks, and maybe check with a voltmeter if it`s receiving power.
PS. During steamprocessing the pump just have small ticking sound, and not the same sound as during brewing. There is no way around this Fill system message, and the reset function is not activated until any System Messages has been clared.
SOURCE: Jura E9 grinder spins but does not grind
I had a similar problem, and solved it by turning the grinder by hand against resistance. Apparently the grinder wasn't really turning during the cycle and needed to be cleared. If your beans are "hopping" this may be a different problem.
Testimonial: "Grinder is turning but old bean oil is clogging it. Stirring beans on next brewing after drying the grinder was also customer services recommendation"
