SOURCE: My Starlight papasan craddle swing
Make sure the legs are pulled out all of the way by pulling the legs outward. Make sure the buttons snap into the notches in the motorized frame. Also check to be sure the legs are locked into position by pushing the legs inward. The legs should not move. Also if you can adjust the swing from side to side make sure it is locked in place. That should fix it.
SOURCE: Hi, I have a fisher
You can purchase replacement motors from Mattel (Fisher Price's parent company).
It will be one of the following 3 products, just pick the one that matches what you have now:
https://store.mattel.com/ItemDetail.aspx?cat=140&item=58050
https://store.mattel.com/ItemDetail.aspx?cat=140&item=59702
https://store.mattel.com/ItemDetail.aspx?cat=140&item=58374
SOURCE: When you turn the swing
try new batteries, it sounds like the motor is trying to turn the mechanism, but doesn't have enough power.
SOURCE: fisher price aquarium cradle swing won't swing
It's been a while since I have dealt with these. There is usually an off switch located along the swing bar check to make sure it is in the on position and that the switch itself hasn't been disconnected. Double check to be sure the swing is level and the safety isn't stopping it from working.
SOURCE: fisher price my little lamb baby swing will not swing
If it makes a sound but doesn't swing then the metal rod inside the motor casing was probably bent. If it makes no sound then it could be several different problems.
If it does make noise (my daughter did the same thing) then you can fix it, though it's not the easiest fix. Unplug it/remove batteries, and you'll need to remove the legs. Start removing screws to get to the motor casing, the first ones you'll need are in the battery compartment. Be careful as you're doing this, once you get the plastic casing off things can move around. Have someone as a second set of eyes if you need it.
Once you can see the guts look for a thin metal stick, no thicker than a telephone cord. Yup, that's what moves the swing. The metal is easily stressed. You can carefully power it up if you want to see how it works or make sure that little thing is moving. There's a small gear underneath all that, but you don't need to get to it.
Instead, you'll need to beef up that little stick. I used a leftover rubber gasket from a ceiling fan first, then I was so amazed it worked I took it back apart and used a longer piece of rubber tubing with a harder plastic tube over it (it's a very tight fit). It will still need to rock back and forth in it's little hole so don't go too crazy.
The one drawback is that I think it has a louder operation now, but the one thing that both my kids adored with the swing was the rhythmic tick-tock. If baby is happy, mama is happy.
Anyway, FP will sell you a whole new motor, or if you an find the exact part number you might be able to get a new pendulum. But I like fixing stuff, and I like free better, so if this is what yours needs I hope it helps. If this is but you don't follow what I've written I'm happy to try and take pictures of mine.
Testimonial: "thank you very much!"
