Electronics - Others Logo
Posted on Nov 02, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Treadmill has automatic shut off sensor when i walk on it for a time
I bought treadmil - lifefitness 9500 hr next generation rebuilt treadmill. no owners manual. while walking on it the electronic readout comes on displaying - no user detected - then shuts off. i have to press enter to start it back in action again. i was wondering 1.) is there a way to stop this 2.) is there something wrong with this
Larry
Level 3:
  • Master 5,042 Answers
  • Posted on Dec 31, 2017
Larry
Master
Level 3:
Answers
5042
Questions
Helped
1241106
Points
18413
Sounds like the sensor that detects someone is on it is bad, Here is the service manual that should help.
LifeFitness 9500 Series Service Manual
5 Related Answers
Anonymous
  • 1865 Answers
  • Posted on Aug 29, 2009
SOURCE: Pro-form 320x treadmill slows down then motor stops.
Sounds like it is overheating, you have to disassemble the unit and find why it might be overheating
Anonymous
  • Posted on Sep 12, 2009
SOURCE: Proform 520
Not sure what's happened here. treadmill won't turn on when red key is inserted. checked electrical plug to make sure it worked. I couldn't see that there's anything wrong with the red key. Have any ideas?
Anonymous
  • Posted on Dec 01, 2009
SOURCE: lifefitness 9100hr treadmill cut out
iv had similar problems, only happened once tho - i switched it on after a few mins it would go off.
iv read to dismantle the stop switch, clean and replace the microswitch. where can the microswitch be found from?
also, is the red stop switch that needs looking at? how can i remove it?
i was wondering on how i can service/maintain this properly, can anyone advise my on how to give this a service.
Anonymous
  • Posted on Dec 30, 2009
SOURCE: I have a Proform 770 EKG Treadmill jerks and squeaks
The drive belt was loose. I tightened up the motor just a smidge using a crow bar. That solved the problem.
Anonymous
  • 83 Answers
  • Posted on Apr 30, 2010
SOURCE: Treadmill Incline Works, belt does not move
Check the drive belt. It may be loose or broken. If the belt is loose, then to tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down.
How to replace walking belt ?
Although a different machine, the processes are similar. Just be sure to accommodate to your hardware. I will be including a link to your manual also.
Link to manual;
http://www.sportsmith.net/images/product_support/lifefitness/Treadmills/Tr9500/9500%20Treadmill%20Manuals/Operation/m05100k26a200%20Classic%2095HR%20Treadmill%20Operation.pdf
Link to Video on how to replace deck and belt;
http://www.sportsmith.net/video-player.aspx?did=36339058-8E69-402F-A2E8-182887979B5C
How to adjust unit measurement
How do I change from mph to kph on a 9500 hr lifefitness treadmill please
How do i get the hours info from a life fitness 9500 hr elliptical
go to the MENU, and see the details.
However your must read your instr. manual and see how to enter.
God bless you
Finding total mileage and useage hours on a Life Fitness 9500 Treadmill
unfortunately, is NOT possible, Not miles or kms in treadmills.
You have to buy the eagle eye.
God bless you
My lifefitness treadmill gives a static shocks...
hi you have a wire touching the body of the treadmill somewhere, but an easy fix is to go to any car parts shop and buy an antistatic strip. just attach that to the body of the treadmill making sure it is touching the ground, this will def fix your problem. i had the same with mine i spent ages looking for the wire etc but just waisted alot of time. the strip has worked very well.and cheap to buy under £5.00.
2helpful
How do i reset the waxer on a 9100 lifefitness treadmill?
Press these buttons:
101–ENTER–
HILL–RANDOM–
FIT TEST.
Program lights come on. Display will scroll toWAX DELAY OFF.
Press speed "UP" or "DOWN"
to toggle to
WAX DELAY ON or OFF.
How do I access the service menu on a lifefitness 9500HR treadmill?
To get to the service menu start by pressing the pause button and keep it held down as you hit the clear button twice. The treadmill will reset and go into the service menu, and now you quite pressing the pause button.
2answers
Heart rate monitor chest band not working with Life Fitness 9500H
This mean that you unit is not equiped with a receiver inside the treadmill. Some models that was an option. Polar is the only brand that works with Lifefitness. You may have a bad upper display board. You can buy a replacement for a small amount of money.
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Top Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
