Del jay , post exect model of PC.
full models,
acer veriton L670G, in english a very very tiny PC desktop and HUGE Limits on upgrades. as all are.
so you want to fit a newer faster GPU card here, you say..
the manual and photos of the guts answer that in second flat.
first there must be PCI-e slot there, that can do GPU lane count X16
ig came with super old intel CORE 2 CPU and IGPU inside it,
the mobo has no GPU slots at all, so where would you plug it in, answer CAN NOT.
it is a what you see is what you got, PC, more ram sure. (if not max now)
next time buy a real PC, if not needing dinky do PCs for a DORM buy a real desktop
one that is good and not expensive is a DELL 3020MT or DT, but never smaller SFF or micros ever.
if flush with cash, dell 9020MT can do 2 times the ram of 3020 (they are sisters)
My guess you dream of gaming (called AAA prime games $60+) if yes, this 670g is useless as lips on a chicken
all post below are wrong the question was CARD.
not drivers. at all
it was a hardware question, hardware upgrade and is impossible.
SOURCE: can I upgrade the graphics card in an acer
Yes on a desktop you can put a new video card, just put on a PCI socket on the Motherboard
SOURCE: Acer Veriton M464 E4700 2.6Mhz cpu upgrade on MCP730 Mobo
Go to www.newegg.com and whatever you want to upgrade click on that item and match it up with your current board (by looking at the specifications and matching them). I suggest to buy a new mobo and all new processors and ram. You can use your old case, hard drive and all that good stuff that is removable.
SOURCE: upgrading graphics card
Connect the monitor to the onboard video connector first. then
you need to disable the on-board graphics in the BIOS save the setting and shutdown. Then connect the monitor to the GeForce video connector and boot up then you will get a video signal on the GeForce video card.
SOURCE: acer veriton 5800
Follow the link for driver downloads
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com&siteid=7117&areaid=2&formid=3394#results
Mark
ps. thanks for the rating
