SOURCE: laptop to tv
Hi, Perhaps you have to activate the S-Video output of your laptop. In most laptop models, this is done with the use of the Fn key + some other function key like F5 or F6 or whatever it is being used by your specific laptop model. You can also check if this feature in enabled in your Display Properties/Settings/Advanced/Monitor or amongst the other tabs/choices. At other times, you may need to change your laptop's screen resolution to match the HDTV's capability/capacity. Hope this be of some help/idea. Pls post back how things turned up or should you need further information. Good luck and kind regards.
SOURCE: samsung syncmaster 740n monitor problem
Add a 50 ohm between pin 5 and 6 of the NT68F63LG IC.
Go to this link to learn the details. http://translate.google.com/translate?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&sa=X&oi=translate&resnum=3&ct=result&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220
I tried this fix on my monitor and it works now.
SOURCE: SAMSUNG NC10 CANNOT SWITCH ON
take it back and replace it it should still be under warrantie
SOURCE: How do I remove the keyboard on a Samsung R610
The keyboard connector come in two types.
A plastic connector and usually has a plastic tab that you pull to lift the connector off, DO NOT PULL on the ribbon cable.
The other type is, a ribbon cable that is inserted into a plastic socket on the motherboard. To release the ribbon cable, lift up the plastic catch on both ends of the to release the ribbon cable. When you want to insert the ribbon cable, make sure the catch is in the up position before you insert the ribbon cable, then insert the ribbon cable and the push the ends of the plastic catch down to lock in the ribbon cable.
