Whirlpool Duet GHW9150P Front Load Washer Logo
Anonymous Posted on Oct 05, 2011
F- code does not show code in book what and how to remedy the problem?
  • 1 more comment
  • Michael Thomas
    Michael Thomas Oct 06, 2011
    Hello there and welcome to fixya
    Can you please provide me with the exact f-code you are experiencing so i can get you the right information you will need to troubleshoot this problem
  • Anonymous Apr 05, 2013
    The washer will complete app. 80% of the cycle and then stop and give the error message, F6. For some reason, it will not complete the final spin cycle.
  • Michael Thomas
    Michael Thomas Apr 05, 2013
    hello there again sorry you could not find any error code for this here is some info that may help youIf the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components .If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer. i would first test out the timer this isthe most common issue with this machine ok please get back to me if you are able totest and i will give you the instructions on how to do this ok? best regards Mike
Michael Thomas
Level 3:
  • Whirlpool Master 3,056 Answers
  • Posted on Oct 06, 2011
Michael Thomas
Whirlpool Master
Level 3:
Answers
3056
Questions
52
Helped
1307386
Points
10935
Hello there again here is some more info for you
Whirlpool Washer Troubleshooting: Error/Fault Codes Whirlpool Washer Troubleshooting has been made easier since newer Whirlpool washers generally display a consistent range of error codes (or fault codes) when problems develop so that owners and service personnel can quickly troubleshoot the problem and fix it easily. The Fault codes address a wide range errors that occur with Whirlpool washers, everything from water and power problems to basic maintenance routines. We have put together a comprehensive list of Whirlpool Error Codes for some specific and general Whirlpool Washer models to help you with your Whirlpool Washer Troubleshooting task.on next post
2answers
My Walgreens HD 303 will only give Err code 3. It will not give pressure. What remedy do I have
Doesn't the book give codes? Is the battery fresh? Is the cuff tight on your arm? Is the tube clear of obstruction like you arm resting on it?
My sharp al2021 showing f5-02 and e7-11 what can do to work
The service manual was not available for the AL-2021 but the error codes are the same for the AR-5316
F5-02 error cause and remedy
Sharp AR 5316 Service Manual Page 27
E7-11 error cause and remedy
Sharp AR 5316 Service Manual Page 26
1helpful
What means the code error F26?
F26 Boiling protection. The program is interrupted and the drain pump is operated. The display shows Technical fault F26. Call the Service Department. The buzzer is activated for 2 minutes.
Cause:
Temperature at NTC temperature sensor has exceeded 194?F (90C).
Remedy:
Check the heater relay and replace it if necessary.
Cause:
NTC temperature sensor providing inaccurate information.
Remedy:
Replace the NTC temperature sensor.
Cause:
Heater relay closed.
Remedy:
Replace the heater relay.
Aug 25, 2014 • Dishwashers
Water remains in machine. Machine stops after a minute or so and diplays F11.
F11 means Drainage fault.
Water present in appliance and is not being drained off. The display shows Drain fault F11. The buzzer is activated for 2 minutes.
Background information:
After each drain pump step, the circulation pump operates for 2 seconds and heater pressure switch B1/13 checks the water level. If it is too high (large quantity of residual water remaining in the cabinet), the drainage time is extended. If, after a further check, the water level is still too high, then the program is interrupted, the fault code is saved and the drain pump is activated. Fault code F11 is also registered if heater relay 1K1 is not activated after the fault code F51 register check; see Section 080-3.18. Drain hose kinked. Remedy: Check the drain hose for correct positioning.
Cause: Drain blocked.
Remedy:
1. Clean the on-site drain.
2. Check the sump drain.
3. Check the filters.
4. Check the heater pressure switch and replace it if necessary.
Cause: Ball in non-return valve in sump has not opened (e.g., jammed).
Remedy:
Clean the non-return valve in the sump or replace it if necessary. Cause: Foreign objects in the drain pump.
Remedy:
Clean the drain pump and its impeller.
Cause: Drain pump defective.
Remedy:
1. Check the voltage supply to the drain pump.
2. If correct voltage is present, check the drain pump motor winding.
3. Replace the drain pump, if necessary.
Cause: Foreign objects in heater pressure switch.
Remedy:
Check the heater pressure switch for blockages and correct switching point.
Cause: Heater relay defective. Heater relay (coil or contacts) becomes defective during the drainage step (after fault code F51 register check).
Remedy:
Hope this helps to solve it.
5helpful
Have just bought a secondhand Miele G7859 dishwasher. When turning on to any programme, it shows F11 fault code and beeps. I'll happily work through any suggestions! Thanks in advance Andy
F11 - Drainage fault
This code means that water present in appliance and is not being drained off. The display shows Drain fault F11. The buzzer is activated for 2 minutes.
Remedy:
Cause:
Remedy:
Remedy:
Cause:
Remedy:
Cause:
Remedy:
Cause:
Remedy:
In other cases, owners found a piece of wood inside the door latch mechanism and removed it. The F11 error has not appeared since.
Hope ths helps.
May 20, 2011 • Dishwashers
1helpful
Dishwasher miele g2582scvi fault code f25
Check this out.
F25 Desired temperature fault At the end of the wash program, the display shows the message Technical fault code F25 - Call Service Dept. The Status LED flashes. The buzzer is activated for 2 minutes. During the heating stage, the desired temperature has not been reached within the given time (minimum 75 minutes). In subsequent wash blocks, after this fault has registered, the heating is not activated and no rinse aid is dispensed.
Cause:
Heater defective.
Remedy:
Replace the heater.
Cause:
Remedy:
1. Check the heater relay solenoid.
2. Check the heater relay solenoid voltage (12VDC) from the electronic.
3. Replace the electronic, if necessary.
Cause:
Excess quantity of detergent or rinse aid dispensed. Excess foam has developed.
Remedy:
Check the dispensed quantities of detergent and rinse aid. Follow the information given in the operating instructions F25 Desired temperature fault At the end of the wash program, the display shows the message Technical fault code F25 - Call Service Dept. The Status LED flashes. The buzzer is activated for 2 minutes. During the heating stage, the desired temperature has not been reached within the given time (minimum 75 minutes). In subsequent wash blocks, after this fault has registered, the heating is not activated and no rinse aid is dispensed.
Cause:
Heater defective.
Remedy:
Replace the heater.
Cause:
Remedy:
Cause:
Remedy:
Mar 15, 2011 • Dishwashers
2answers
No hot water. Display reads ER3.
Hi, If you have the book for this system, then go to the problem solving to the rear of manual. This will tell you what code ER3 means, and what you need to do to correct it.
If you dont have the manufacturer's book then try to down load it!.
All boilers and water heaters have different fault finding codes, so can-not give any more info, unless you can tell me the exact problem.
Thanks Paul.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
