SOURCE: I cannot go into my
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response Thanks, Joe
If you have an Efficient/Speedstream 5100b or 4100 set to do PPPoE:
1. In your web browser browse to http://192.168.0.1 This address will be located on a yellow sticker on the bottom of your modem.
2. The first screen will ask you for your Modem Access Code. This also will be located on the same yellow sticker.
3. At the login screen type in your SBC member ID and password.
4. Click Connect.
5. If everything is succesful you will get a screen that says, "You Are Connected." and your Internet light will go solid green. If you username or password is invalid you will get a screen stating such. If there are other problems you will get a screen stating, "The DSL connection is down."
If you have the 2-wire Home Portal:
1. In your web browser browse to http://homeportal/setup or to http://192.168.1.254 (Or on older models its http://172.16.0.1)
2. Put in your 2-wire system password at the prompt.
3. If they key code is not already filled in put in 522P-22P4-6262-22AT-F2NV for PPPoE and 522P-22P4-2E62-22AT-F27W for static then next.
4. Put in your full member ID and password and next.
5. Select your timezone
6. You should now be connected.
If you have another modem other than the 2-wire Home Portal or 5-LED "5100B",
Windows XP:
1. Go to Start > Control Panel
2. Double click on Network Connections
3. Click the link on the left side that says "Create a new connection"
4. Welcome to the New Connection Wizard! Click Next.
5. Choose the top option labeled "Connect to the Internet." Click Next.
6. Choose the middle option labeled "Setup my connection manually." Click Next.
7. Choose the middle option labeled "Connect using a broadband connection that requires a username and password." Click Next.
8. It asks for an ISP Name. Basically, this is just going to name the icon, so name it whatever you prefer. We usually recommend "DSL Connection." Click Next.
9. It asks for your username and password. Enter both those in, and then uncheck the bottom checkbox that says "Turn on Internet Connection Firewall for this connection." If you feel confident that you know how to turn this off later, you may leave this box checked. When done with all of that, Click Next.
10. Completing the New Connection Wizard! Check the box that says "Add a shortcut to this connection to my desktop." Click Finish.
Iām happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Trying to connect to my dlink router. Asking for
That problem would be solve by resetting your router,,,
1.turn on your router..
2.wait for about 1 min.
3.look for the reset button of your router(usually at the back) .
4.press it for about 10-15 sec. (or until all lights turn on then off. )
5.and there you go.. you can know access your modem with its default ,,
SOURCE: my problem is how to change my password.i already
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash.Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Which password are you calling about? Are you calling about the password for your email or the password for your NetGear?
