SOURCE: Sonar Producer 6 - Audio/midi devices/controller-surfaces..Which settings??
o always run at 0 on play back recording -3 with drums use anlog cables then select anlog 48000 24 bit if u can if its digital cable might use 96000 bit rate ok spdif watch it close on digital for digital clips never go in red keep steady balence cheak your sorse tape how loud is that adjust your stuff to sound good at peaks never hit red in digital mode does this help sum
SOURCE: Sonar 6 Producer - palyback quality issue
I had this problem today whilst installing Sonar on my new laptop. It wasn't the click track. It was the playback glitching, clicking and rattling. I put the buffer size to maximium but it was still happening.
I got round it by downloading the latest version of ASIO4all (2.9 beta4) and installing it. I then opened Sonar 6, options, audio, advanced, then selecting ASIO in the driver mode drop down box. Then I closed Sonar and reopened it.
If you use one device for recording and playback it should work now but if like me you use seperate devices or if it doesn't work click, options, audio, general, ASIO panel, advanced options. Here you can select your inputs and outputs. Play around a bit here. Mine worked when the output of the playback device was selected and both the input and output of the recording device was selected.
ASIO4all sorted out my latency issues as well.
Hope it helped.
SOURCE: Cakewalk Guitar Tracks Pro 3,
Options>Audio>Advanced.......
Select "MME" from the Driver Mode dropdown menu....
this worked fine for me......
let me know if it works...
SOURCE: missing manual for guitar pro tracks 3
Here is a URL i found with a manual that might help?
Link
I have exactly the same problem with synchronisation, when I record a second track and try to playback with the first track!
