Gbc HeatSeal Ultima 65 Laminating System Logo
Anonymous Posted on Oct 04, 2011
Paper rolled on heater roller. How do I remove?
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on May 22, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
8828
Points
5
I fix roll laminators for a living. Its best with GBC machines to remove wraps where the film is stuck to the roller hot. trying to remove ilm adhered to the roller cold can not jusst remove the film but the rubber roller surface. Do note GBC heat rollers espically the red ones are over 500 bucks each:( Its easy to damage those rollers making the machine junk....
This question is old but I answered it for the benefit f others coming here bob haller service and sales 412 366 4906 pittsburgh pa. I answer all phone questions for FREE, and in the pittsburgh area offer free no cost no obligation estimates
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 16, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5641
Points
AFTER IT COOLS OFF REMOVE LAMINATE FILM FROM FEEDING INTO MACHINE, CAREFULLY REMOVE PAPER AND ANY LAMINATE FILM FROM ROLLERS YOU MAY NEED TO CLEAN WITH ALCOHOL THEN WHEN ALL IS CLEANED OFF RETHREAD LAMINATE BACK INTO MACHINE. THIS CAN BE TIME CONSUMING USING REVERSE AND FORWARD TO REMOVE LAMINATE UNTIL ALL IS CLEANED.
scott westin
Level 1:
New Friend:
  • Contributor 33 Answers
  • Posted on Oct 02, 2015
scott westin
Contributor
Level 1:
New Friend:
Answers
33
Questions
0
Helped
56443
Points
52
Remove stuck film when the rollers are hot, this allows the glue to release from the rollers, you still have to be careful not to pull too fast as you can damage the orange heat rollers. Goo Gone from wall-mart always helps. West Laminating Svcs 405-324-6092
MY FR-2650A always PaperJam...Cannot feed the paper
Here are some steps you can try to fix the issue:
  1. Check the paper: Make sure you're using the correct type of paper for your calculator. The FR-2650A requires 2 1/4 inch (57mm) wide plain paper rolls. If the paper is too thick or too thin, it can cause jams.
  2. Remove any jammed paper: Turn off the calculator and remove the paper roll. Gently remove any jammed paper from the paper feeding mechanism. Make sure to remove any torn pieces of paper or debris.
  3. Clean the paper feed mechanism: Use a soft, dry cloth to clean the paper feed mechanism. Dust and debris can accumulate in the mechanism, causing paper jams.
  4. Check the paper feed roller: Use a cotton swab or soft, damp cloth to clean the paper feed roller. Make sure it's free of debris or dust.
  5. Replace the paper roll: Make sure the paper roll is properly installed. The paper should unroll from the bottom of the roll towards the front of the calculator. The paper should be flush against the paper feed roller.
  6. Test the calculator: Turn on the calculator and test it by printing a few lines. If the paper still jams, try a new paper roll.
If none of these steps work, there may be a mechanical issue with the calculator. In this case, it's best to contact the manufacturer or a professional repair service for assistance.
1helpful
There is a piece of paper jammed in the roller, but we can barely see it. We have taken the doors off but have not removed the rear panel. We can see the paper but unable to get a hold on it. What do we...
1) if you have a vacuum cleaner try use vacuum cleaner to suck the paper out.
2) IF YOU CAN TOUCH THE ROLLER, TRY TO ROLL THE ROLLER TO ROLL OUT THE PAPER.
1helpful
3answers
Canon ir400 paper jamming at heater section
constant paper jam in canon ir 400 heater section and delivery door section there is paper in total machine in any where, all the sensor in heater section and delivery door section are replaced.
plz. kindly suggest what is problem.
The roller does not roll. We can't print labels and we are open for business now.
hello tconnersvrve!
open cover - remove the paper roll and do a test print without paper. look if roller mechanic is working, if so, then re-insert paper roll correctly and do a testprint. if no move is detected, then motor or motor drive has problem - service issue.
regards
1helpful
Paper will stuck at the heater
HI i think you have a bad upper fuser roller thats why the paper rolled up with it or maybe there are finge clow are not good first of all just remove paper and just clean the upper fuser roller with fuser oil if yours fuser roller and finger clow are not damaged it will work fine enjoy
thanks
1helpful
The printer is saying there is a paper jam but there is no paper stuck any way in the machine.The resume button does not resolve the problem.
The paper jam may not be very visible and obvious. It may be somewhere after the rollers. Some paper may be stuck in some place in the paper path. Open up the printer and clean the insides with a soft cloth and a brush. That should remove all the bits of paper inside. OR the teeth on the roller sides may have some dirt stuck on them which does not allow the rollers to roll freely and hence is as bad as paper jam. The idea is that the rollers do not roll whether because of paper or some dirt on the roller teeth. They have to be cleaned.
1helpful
3answers
E002 canon 6317
E002
1)due to fuser unit temperature control fault.
2)try to reset the machine by tuning on and off
3)fixing thermister or thermoswitch faulty due to cannot maintain fixing heater temp causes E002 appear.
4)check any paper roll over the surface of fixing roller.try to remove it.
5)fixing roller or fuser roller located near to printing output.
I have a Panasonic Telephone Answering System with Facsimile Model no. KX F250. The rolled paper won't advance, even though it sounds as if it is. I have checked for papers jams, paper scraps between...
THere must be a rolled paper in the roller exit...
try to remove is there is such...
roller exit is located on the cover...
it is a long black roller about 8 inches long.
its color is black...
is you see white long roller on the cover, that is the problem....
remove that rolled paper
HOPE it helps.
GOD BLESS YOU.
JOHN 3:16
Paper wrapped around the red roller
lift the cover remove all the cartridges and the drum unit slowly and carefully and slightly pull the upper side of the paper not the lowerside and if it is rolled completely you have to open the heater unit to remove if you donot have any technical knowledge do not try because the red roll you are taking is a costly thing,call the service technician and get it repaired that would be more cheaper.
Top Gbc Office Equipment & Supplies Experts
ADMIN Andrew
ADMIN Andrew
bvmihai
Ngoro
Are you a Gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
