Sanyo Microwave Microwave Oven Logo
Anonymous Posted on Oct 04, 2011
My microwave want cook - Sanyo Microwave Microwave Oven
Anonymous
Level 3:
Genius:
  • Master 1,456 Answers
  • Posted on Oct 05, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1456
Questions
0
Helped
475738
Points
4013
Hello
and/or circuit breakers, particularly in the case of recent power failure, and reset if necessary.
Unplug the microwave, wait 30 seconds and plug back in to the power supply to reset the microcomputer.
Open and close the microwave door firmly and press "Stop/Reset." Select a new cook time and press "Start."
Ensure a proper cooking temperature and/or time is chosen, as low cooking temperatures or short cooking times may prevent the microwave from heating food appropriately. Press "Power Level" to ensure the microwave is cooking at 100 percent power.
Contact an authorized service technician if the problem is still unresolved.
Emmerson turns on and counts down but no cooking happens.
If your Emerson microwave is turning on and counting down but not actually cooking or heating the food, there could be a few potential causes for this issue. Here are some steps you can take to troubleshoot the problem:
  1. Check Power Levels: Make sure the microwave's power level is set to the desired level for cooking. Some microwaves have adjustable power settings, and if it's set too low, it may appear that the microwave is running but not cooking properly.
  2. Door Interlock Switches: Microwaves are equipped with safety interlock switches that prevent the microwave from operating when the door is open. If any of these switches are malfunctioning or not engaging properly, it could prevent the microwave from cooking. Ensure that the door is fully closed and the switches are working as intended.
  3. Turntable and Support: If your microwave has a turntable, make sure it's properly seated on its support and able to rotate freely. If the turntable is not turning, it could result in uneven cooking or no cooking at all.
  4. Magnetron Malfunction: The magnetron is the component responsible for generating microwave energy for cooking. If the magnetron is faulty or not functioning properly, the microwave may appear to operate but won't actually heat the food. A malfunctioning magnetron usually requires professional repair or replacement.
  5. High Voltage Diode or Capacitor: The high voltage diode and capacitor work together to convert the high voltage output from the transformer into microwave energy. If either of these components is defective, it can prevent the microwave from cooking. Again, professional repair may be necessary.
  6. Control Board or Circuitry Issues: A malfunctioning control board or other electronic components could also lead to a situation where the microwave appears to operate normally but doesn't actually cook. If you suspect control board issues, it's best to contact a professional technician.
  7. User Manual: Double-check the user manual for any specific instructions or troubleshooting steps related to cooking issues. The manual may provide guidance on common problems and their solutions.
If you've checked these common issues and the microwave still isn't cooking, it's advisable to stop using it and contact Emerson customer support or a professional appliance technician for further diagnosis and repair. Microwaves contain high-voltage components that can be dangerous to work with, so it's important to prioritize safety and seek professional assistance if needed.
I have a lamona combi microwave 7150 how do I set it to microwave only everytime I set it the grill light comes on as well.
To cook with microwave only, press "Microwave/Grill/Combi", once, the screen will display "P100". Press "Microwave/Grill/Combi" to select the power level. Then press "Start/+30Sec./Confirm" to confirm and turn the dial to set cooking time. Then press "Start/+30Sec./Confirm" to start cooking on microwave only.
To switch to microwave/ grill combination cooking, choose C1 or C2 when selecting the power level.
See page 14 and 15 in the user manual.
I’d like to cook a pan of lasagna. Directions for regular oven is 400 for 1 hour 15 mon. Do I use the same directions?
Hello, Peggy -
To cook lasagna in a microwave oven, you will need to follow a recipe which is just for microwave cooking.
You can find some recipes for lasagna cooked in a microwave oven here:
https://www.tasteofhome.com/recipes/microwave-lasagna
here:
https://www.realsimple.com/food-recipes/browse-all-recipes/microwave-lasagna
and here:
https://www.epicurious.com/recipes/food/views/microwave-lasagna-with-spinach-mushrooms-and-three-cheeses
You can find more recipes for lasagna cooked in a microwave by using your favorite search engine (Google, Bing, Yahoo Search, etc) by using the following search phrase:
lasagna microwave
Note: If you cook a traditional lasagna recipe in the microwave for 1 hr. 15 min. (even at 1/2 power), you will have a baked brick of charred lasagna.
Best wishes.
Microwave arching
faulty microwave module replace it
Panasonic microwave
I would check the cooking instructions on the side of the pizzas packaging. If microwave cooking is not listed I would not recommend cooking it in a microwave as this could make the food unsafe to eat.
But if you're short of an oven I have found a guide on barbecuing a pizza:
How to Cook Pizza on Barbecue
Microwave still continues after cooking time is ended
It is the fan. Im guessing it only happens on combination cook and not when you are only using the microwave setting. It happens because the oven is hot and it helps to cool it quicker. It is normal. The microwaves are not working and neither is the oven-just the fan.
When we first turn on the microwave there is like a mini-explosion and a fiery spark, but after that the microwave goes through its cycle and cooks the food. But we are afraid to try it again.
pls do not use any aluminum or metal material INSIDE the microwave, this can cause the problem
I assumed, but pls consider the ff info...
Be sure to use nonmetal utensils in the microwave.
For microwave cooking, cut meats and vegetables in uniform sizes to make sure that they cook evenly.
Paper plates, cups, and napkins can be used in the microwave. But don't use foil-lined paper products, paper towels that include nylon or synthetic fibers, or newspaper.
When using plastic roasting or cooking bags in the microwave, discard the wire twist tie and use a plastic fastener or a piece of string instead.
To ensure that food cooks fully and evenly in the microwave oven, stir food and turn dishes periodically while they're cooking.
2answers
Rack in microwave
You should not have any metals in the oven when the microwave is on. If you are just doing convection cooking, the metal rack should be in so that what you are cooking is raised up so the hot air can surround what you are cooking.
Top Sanyo Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
