Hello Howard, There are two different kind of cordless drill chargers. One is a smart charger that will not overcharge your battery. It usually has a stand alone base that the battery plugs into and sometimes may have a red and/or a green light to let you know it is charged. This charger will stop charging when the battery is fully charged after an hour or less. The other one is a dumb charger that can overcharge your battery if left on the charger too long. This charger usually has a square or rectangular transformer that plugs directly into your wall receptacle. This charger may take up to eight hours to fully charge your battery and will continue to charge until you unplug it.
SOURCE: New Black and Decker, 18 volt, cordless drill. I
I oil mine up to help the jaws move . also check the screw at the base of the chuck inside its a standard head. shine flash lite where you put the bit it holders the Jacobs chuck to the shaft.
SOURCE: black and decker cordless drill trigger
Ok, first check to see if the trigger lockout has been engaged, it's a small level at the top of the trigger ( I know this sounds silly, but it happens sometimes). Flip it side to side to see if you can hear the selector moving the switch inside the drill. If the selector moves freely without engaging the switch, you'll have to disassembly the drill housing to put the selector back into the lever so it will work.
Just take out all the screws in the housing and carefully remove the one side and look at the switch lever and make sure it is inside the slide selector lever.
If that isn't the issue, I'm afraid that the electric trigger/switch has failed and this isn't a part that can be disassembled and repaired by a DIY'er. I've attempted it when mine failed and found out it's a sealed unit and wrapped in a copper heat shield that dissapates heat when the variable speed is utilized and you end up destroying the switch housing in the process.
However, any DeWalt authorized repair center can do the repair for around $20 +/-, and if your drill is under the 3 year warranty period, it should be a free, warranty repair. Just contact DeWalt's customer service or your local Authorized Service Center (listed in phone book usually), or check the link for finding one near you.
www.dewalt.com or call 1-800-4-DEWALT (1-800-433-9258
Click on the "Services/Support" tab to get info. You can also buy the replacement parts if your drill is out of warranty (call them to verify before takin it apart!) and do the repair yourself.
Hope you find this Very Helpful and best regards!
SOURCE: charger not charging have 2 new chargers neither 1
You should probably contact Customer Service regarding this. I'd say it's a problem with the batteries rather than the chargers considering this looks like a recent EPC model - 1800 444 224
SOURCE: I have a black/decker drill
How old is the battery there olny good for 3 or4 years and if you leave themin the cold they won;t last half that long yours is an older one the battery dosn;t come off it although i like black and decker i would have to say even if it was the charger and you got a new one the battery wouldn;t live vary much longer
SOURCE: MY 1HR CHARGER FOR MY BLACK AND DECKER 18 VOLT
you can go to Blackanddecker.com and buy a replacement, or go to any major store that sells B&D or DeWalt and but the replacement charger. I would recommend taking the old one with you to ensure the proper one is bought.
