Sounds like the blower motor is getting hot and cycling on internal motor overload. Probably airflow or the blower bearing or capacitor. Turn off all power to the unit then you need to check the filter, Evaporator coil to see if air is getting through it. When checking the coil for a blockage you need to remove a side plate, it's triangular and check the entering air side of the coil to see if its blocked. You need a volt ohm meter with a micro-farad scale to check the blower capacitor and motor amps. You could have a bad motor bearing.
SOURCE: My GOODMAN furnace GMH80703ANAA Starts but quits 5 seconds later
You have a flame sensor that may just need cleaning take out and take fine sand paper or emery cloth and clean
SOURCE: weatherking furnace is starting and stopping
This just sounds like a couple of problems. First, your blower is designed to only turn on once the heat exchanger heats up, so the flame will be on for a minute or two before the blower starts. it sounds like your blower is cooling down the heat exchanger too fast and causing it to shut off so it can warm up again...check blower speed for heat, it should be the lowest speed (black wire). Blue=medium speed, red= high speed. second problem could be your flame sensor rod is calcified, you just need to locate this and clean it off with some fine sand paper.it is located in the flames near the burners. Also change your filters, for proper air flow through your heat exchanger.
SOURCE: lennox furnace 17 yeanrs old. flame comes on and
I have a Lennox G40UH furnace. The burners fail to ignite about every 5th time. The furnace will try to ignite the burners then shut down. Once in a while the temp will drop down to 62 then fire up. I have only gotten a Diagnostic code once "Watchguard - burners fail to ignite" once I shut the power down and it started.
The furnace is clean, 5 years old, the flue is not clogged.
SOURCE: XE 90 gas furnace--furnace will light and run for
hi check out the temp rise and fall on the fan control see if he has left the blower in the summer swich postion where it runs all the time
SOURCE: furnace short cycles
You could have a bad overtemp sensor which is activating at too low a tempreture. They should not be that expensive. I would just replace it to eliminate the control if it is bad. It is a small metallic disc attached to the heat excanger. Has two wires coming off it. Approximately 1 inch in diameter. Usually on the front of the heat exchanger. It should have the tempreture that it activates at stamed on it. The temp is probably in celceus. Prior to replaceing it you could determine the activation temp and if you have a thermometer, or better yet an infared thermometer, check it while running to see what temp it activates at. If it is bad it will activate at too low a tempreture and should be replaced. Let me know if you need anymore help.
hardrocko
Thanks for using FixYa
I have a similar model Lennox G8Q3-105-2. Almost exactly the same scenario. Did you ever figure it out? I've cleaned the blower motor and can't be sure but I think it may be worse by a bit.
