SOURCE: Foot control for PFAFF won't work
These machines need to be seen by a technician who can disassemble the motors and replace the carbon brushes. You should have them serviced at the same time since it doesn't take that much longer to do everything.
sewman7
SOURCE: i have pfaff sewing machine model no 262. i have a
Inside the foot control there is a suppressor, it will be a very small thing attached to the two terminals, take it out and discard it because you don't need it.
SOURCE: Pfaff 2020 Foot Pedal--taken apart; need help putting back tog.
Are you able to post a picture of what pieces you have? The contact board may not be pressed down all the way or the contact itself may be bent. You should be able to purchase both pieces if needed from a pfaff dealer.
SOURCE: Are pfaff 1475cd sewing feet compatible with pfaff 1151 machine
Hi. Some Pfaff machines have something called an "IDT" which looks rather like a small, black walking foot behind the pressure foot, to help feed the fabric evenly. Pfaff machines with this IDT need "IDT" pressure feet. (I can't find a listing of which machines have this and which don't, so you'll have to look at your machines or check your manuals.) If both machines have the IDT, then the feet are compatible. If neither has the IDT, then the feet are also compatible.
Hope this helps!
Happy Sewing,
Robbie
SOURCE: Can I get a replacement foot control pedal for
Hi. I found foot control parts for your machine at http://www.sew4less.com/browse.php?CategoryID=21&filter_brand_id=54&filter_model_id=.
Happy Sewing!
Robbie
