Freezers Logo
Nick stem Posted on Oct 03, 2011
I just bought a new Norlake freezer that I continuously open and close because its busy. What's the best temperature to set and the best temperature differential to set? How many times a day should it defrost?
  • Nick stem Oct 03, 2011
    All different kinds, chicken, fruits, onion rings, bread
Anonymous
Level 1:
Guru:
  • Contributor 683 Answers
  • Posted on Oct 03, 2011
Anonymous
Contributor
Level 1:
Guru:
Answers
683
Questions
Helped
136348
Points
21
What is the main product in the freezer?
  • Anonymous Oct 06, 2011
    when yoo are asking temp diffentrial, what is the control your using and range of it, then I can tell, you. also what refrigerant is in it.
SETTINGS DCF520W
The best temperature for storing food is 0 degrees F. I would go to Wal-Mart, K-mart or a dollar store and find a refrigerator/freezer thermometer and set the freezer temperature with that. Best of Luck
What should the freezer temperature shouls be????????????????
Normally, freezers are at 0 degrees. If you have ice cream, shoot for -10 degrees.
hope this is what you are looking for.
Norlake freezer 6x6 not freezing enough
Normally freezers are kept at zero. Most health departments will not allow the temp to be higher than plus 10. If you want to store ice cream, you need to be at minus 10 degrees to minus 15 degrees.
let me know if I can be of any further help.
2helpful
I have a 6x6 norlake walk in freezer. The door remained open for 6-7 hours by mistake and now temperature does not go below 15 degrees. The technician told me to replace compressor as slowly temperature...
I've worked on freezers for over 20 years and have never heard of a compressor going bad because the door was left open. think about a second opinion.
Also, has the cooling coil inside the box developed and frost or ice build up? If so, it needs to be completely defrosted. If you defrost it manually, use a hose hooked up to hot water. Kill all power and hose all build up off. Remove the sheet metal housing ends and be sure there is no ice inside there too. I would go in this direction first.
IN order to kill a compressor under this condition, something really strange must have happened as anything is possible in a refrigeration system. Good luck and hope this helps.
1helpful
Amana freezer on the bottom not keeping temperature
Hi, If you had ice, there is a drain plugged in the freezer. If you had a frost build up, there is a problem with the automatic defrost.
I can help in either case. Please let me know if you need more assistance.
Thakns
Vic
1helpful
I would like to know the standard temperature for a freezer
The factory presets your temperatures to the MID / MID setting of 0ºF for the freezer.
1helpful
Changing Freezers
If your products are already in the frozen state the answer is yes, you can make an immediate transfer. Normally a couple of hours run to allow the temperatures to stabilize is sufficient. The cool down run time also insures the the unit is functioning properly. If you plug it in and transfer the products right away make frequent checks to insure proper operation.
How do turn the temp up on a norlake walkin?
They are usually mounted on the front panel of the evaporator or mounted on the wall behind the evaporator.There is a possibility that the temp. control is at the condenser,and the sensing bulb was slipped thru the wall.Look for the bulb at the back of the evaporator and follow the cap tube.
Top Freezers Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Freezer Expert? Answer questions, earn points and help others
