Hitachi CP-X206 Projector Logo
Anonymous Posted on Nov 22, 2017
Lamp Light on for Hitachi CP-x206 3LCD Projector. I turn on projector, it flashes green light on power button trying to turn on but will not now. Eventually a red light comes on the power and Lamp button on top of projector. Projector will not work at all. Please help...hoping there is easier solution that replacing lamp.
Lampdeng.com
Level 2:
Renaissance:
An user who is expert in 3 categories / brands.
  • Expert 789 Answers
  • Posted on May 31, 2019
Lampdeng.com
Expert
Level 2:
Renaissance:
Answers
789
Questions
0
Helped
197806
Points
977
The mainboard is fault
or
fan is fault
I Supply the Projector accessories,in China.
projector accessories:Laser Diode Module,lamp,bulb,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast...with high quality and competitive price.
Hope to cooperate with you.
Lampdeng Co.,Ltd. (Guangzhou, China) is founded in 2000, is a major supplier of projector lamps
www.Lampdeng.com
5 Related Answers
Anonymous
  • 34 Answers
  • Posted on Dec 05, 2007
SOURCE: Hitachi CP-X250 LCD Projector
If both lights are flashing orange, that means that the bulb needs to be replaced and the filter needs to be cleaned. Make sure you reset the counters for both after you replace them.
Anonymous
  • 440 Answers
  • Posted on Feb 03, 2008
SOURCE: Hitachi CP-L850W lamp reset (No Remote)
easy on botem vent unscrew it then u see screw in ther holding balest of the bulb unscrew it litte pull up action on its arm as u will see lift it all out to get new in then reset timer ok
Anonymous
  • 563 Answers
  • Posted on Mar 26, 2008
SOURCE: Hitachi CP R555 Multimedia LCD Projector
Hi there
In your Menu options there is a subfolder where it either reads lamp or lamp timer.
Scroll down to it and hold down you right or left arrow key on the Projector for a couple of seconds.
Cameron Scott
  • 105 Answers
  • Posted on Apr 24, 2008
SOURCE: Resetting the air filter timer
Hitachi CP- RX60:
Press the RESET button on the remote control or the right-pointing triangle button on the projector for about 3 seconds. Once you see the RESET dialog, use the upward-pointing triangle to RESET. I can't see what you are or are not doing...so please see page 39 of the user's manual (download found below)
Source:
http://www.aboutprojectors.com/Hitachi-CP-RX60-projector.html
Hitachi-CP-S335 :
"The lamp time is the time counted after the last resetting. It is shown in the OPTION menu as the use time of the lamp. Pressing the RESET button on the remote control for about 3 seconds displays a dialog. To reset the lamp time, select the RESET option using the (triangle) button."
Taken from pg 36 of the users manual (download link below)
Source:
http://www.aboutprojectors.com/Hitachi-CP-S335-projector.html
Anonymous
  • 51 Answers
  • Posted on Dec 08, 2008
clean filter and reset the filter timer by advanced options filter timer and hold reset till menu shows then arrow up and it will zero out.
I can't figure out what is wrong with my Hitachi CP-X605 projector.
The ballast (which provides power for the lamp) might have gone bad. Check the voltage its outputting with a digital multimeter.
7helpful
2answers
Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Goodluck..
Flashing red light for lamp
There could be several causes for this. Does the cooling fan come on, it may be defective. There could be something blocking the heat sensor. Is it possible the connector didn't get fully attached when you installed the new lamp?
My projector will not come on. the power light blinks green, then goes to red. the "lamp" light looks like it is coming on dimmly (red)
you need a new lamp:
http://www.shopvsc.com/Replacement-Lamps-for-Hitachi-Projectors-s/291.htm?searching=Y&sort=9&cat=291&show=50&page=1&f-CP-X201=105087
2helpful
Machine powers down and no lamp.
one of the fans may not be working properly or the ballast is shot.
5helpful
2answers
No lamp
whats your location, The power supply is faulty, but fairly easily repaired, if you send it to me, I will sort it out
2answers
No light come on from the projector
Thats the projector telling you that you need to replace the lamp. Lamps usually lasts for about 2000 hours so if you had it for a while you may need to replace it.
www.froogle.com and enter your make and model or go to www.projectorcentral.com and find a few retailers in the US that sells lamps.
good luck
smeags
Top Hitachi Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
old marine
old marine
ZJ Limited
ZJ Limited
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
