Canon PowerShot SD300 / IXUS 40 Digital Camera Logo
John Sincere Posted on Sep 23, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Canon Powershot sd300 4 MPixel camera displays error message " memory card error" and will not operate. WHen tried to change SD cards, with one I know is working in another device, I still get the SAME error message and the camera will not shoot pix. Dont believe it is the SD card as the error persists ever when a new card is installed. Any ideas?
Paul Green
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Canon Expert 527 Answers
  • Posted on Nov 18, 2017
 Paul Green
Canon Expert
Level 2:
Prodigy:
Answers
527
Questions
Helped
232948
Points
686
SD cards have a small micro switch on the side check to make sure your's is open/on.
5 Related Answers
Anonymous
  • Posted on Jan 13, 2008
SOURCE: no memory card error on canon powershot a400
Maybe you have to format the card before the camera recognizes it
t00nz
CameraR
  • 4738 Answers
  • Posted on May 17, 2008
SOURCE: canon powershot sd300 e18 error
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
cricket0321
  • Posted on Sep 27, 2008
SOURCE: sd card error on canon powershot s3
I get a memory card error everytime I insert a memory card. They are not locked and I have tried 4 different memory cards and nothing works. How can this problem be fixed?
Anonymous
  • 3 Answers
  • Posted on Jan 28, 2009
SOURCE: memory card error after inserting SDHC card on powershot A620
the a 620 only goes up to 2 gb no higher
t00nz
CameraR
  • 4738 Answers
  • Posted on May 27, 2009
SOURCE: Black screen problem with Canon PowerShot SD 750
Did you accidentally press the DISP button on the back of your camera? This manually turns the screen on and off to save batteries. Try pressing this button one more time to see if it turns the screen back on.
1helpful
When putting a Lexar Multi-Use 16 GB SDHC memory card in my Canon Powershot A540 I get Memory Card Error message as well Card Locked message. Have tried unlocking it by the slide on side of card, is t
It's a lost cause. The A540 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You need to stay with SD cards, 2GB and smaller.
tip
How to Recover Lost Photos and Video from Canon PowerShot SD780 IS
<span> <span><img src="maggiena_8.jpg" /><br /></b></span>Canon PowerShot SD780 IS</b> may be the slimmest Digital ELPH Canon has ever created with dimensions 2.10" h x .70" w x 3.40" l, .26 pounds and 2.5 display size. It captivates the senses with bold saturated colors and a daringly original design that matches the intensity of Canon's most innovative camera technology.</span> <span><br /></span> <span><span> <p>Owning to its wonderful picture quality as well as high resolution, it becomes the first choice for many photographer lovers. One more reason that it turns out to be so popular is it supports various standard storage media like SD/SDHC, Multimedia Card, MMC Plus and HC MMC Plus memory cards</b>. images, Video and other multimedia file like songs can be saved there. Usually, keeping a backup of data like pictures and other multimedia files is recommended at the very beginning in case the data was lost by mistake in the process of using the camera. However, if you forgot to backup, you have to use a third party program to <a href="http://www.card-data-recovery.com/">retrieve Canon PowerShot SD780 IS data</a>.<br /> <p><br />Cases about losing data</b><br /> <ul> <li>1. When connect Canon PowerShot SD780 IS to your computer and being transferring vocation photos from SD card to computer, accidently your camera shut down due to low battery. After change the battery and restart camera again, you may encounter the error message "memory card error" that means the memory card is inaccessible.</li> <li>2. While reading data or writing data to SDHC card, "I/O device error" occurs and all photos and video miss.</li> <li>3. On the process of shot, message "memory card is full" pops up to you. However, after deleting some pictures, it shows the same result.</li> <li>4. Connect your SD card reader to computer, the window pops up with message "you have to format SD card before using it". After formatting SD card, all your pictures and video lose.</li></ul> <p>Resolution</b><br />If the above phenomena happen, don't panic, lost photos and video in Canon PowerShot SD780 IS are recoverable. First thing to do is stop using camera to shot for fear that the data was overwritten. For the first two cases, make sure the SDHC memory card is properly inserted. If it still can't be recognized, try to use a card reader to connect it to PC. Or else you have to format memory card and use effective photo recovery software to get back lost photos. For the last two cases, you should rely on <a href="http://www.card-data-recovery.com/">Canon PowerShot SD780 IS picture recovery</a> program. There are many effective Canon digital camera photo recovery program available in the internet, just choose the perfect one for your camera. <br /></b><br /><br /></span></span>
on Jul 20, 2011 • Cameras
Just installed a new memory card in my powershot A430 and the camera says memory card error, card is locked. how do I unlock?
What type and size memory card? The A430 works with SD cards. It won't work with SDHC cards.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
When I install a new SD card in my Canon PowerShot A540 it displays Memory Card Error Card Locked. I have moved the tab on the card and it displays the message regardless if the card setting. What
it seems to be the memory card slot is damaged normally 9 contacts connect with MC if any of it doesn't contact, will not work, open and takeout card slot if the contact is bend align it to touch the MC's contacts.
1helpful
My camera is giving me a "no memory card" sign, but the card is inserted correctly. I have taken it out, cleaned it, and put it back, replaced the batteries, and everything. However, to no avail....
If the camera displays Memory card error, No Memory Card, or takes an abnormally long time to write an image to the memory card, when a memory card is inserted or any of the above error messages, make sure that the card is inserted properly. For SD card, make sure that the card lock switch is in the correct position and not stuck in-between.Try formating the memory card ,if after formatting the card in the camera the error persists, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service.
Turn on the camera. "Memory Card Error" displays.
You'd better change a new memory card that doesn't have a problem to check whether it is matter of Canon PowerShot A480,or use another well camera to check if it is error of your memory card.
Purchased new memory card for my canon powershot A520 and I keep getting a "memory card error". I've purchased two different cards and get the same error message. Original card that came with...
From page 145 of the A520 user manual, it appears that the largest SD memory card that this camera is able to use is a 512MB SD memory card. The manual is dated "2004", so this size limitation is not unusual for a camera of this era.
If you've purchased anything larger, there is a good chance that it won't work with this model camera.
1helpful
I have a canon powershot sx110is and when i turn it on it will not take any pictures but instead gives the message "memory card error." When I put it to the display mode it says the same message plus...
First see if the camera will work without the memory card installed. Then format the internal memory using the camera's setting as described in the manual.
Then turn OFF the camera and insert the sd card. Turn on and reformat the card too.
Make sure you have NEW batteries or sometimes things go flakey.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
