Posted on Sep 20, 2008
Nap Feature Sometimes when i try to set my clock, the nap feature comes on. How do i turn it off without resetting it?
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Nov 30, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
5686
Points
33
I press the nap button and hold down the cancel button and it works fine
A
Anonymous
Press and hold the Nap button until the word "Nap" disappears. It takes a a few seconds of holding.
I am not sure how to set the time interval in the nap mode. It starts at 2 hours, and I can't change it.
Ok, this is the way it works, and I keep my clock radio for this feature alone. It is a 2 hour "count down" timer. It is set in 15 minute intervals. Supposed you wanted to take a 1/2 hour nap. Press the button but don't let go. As you hold your finger down the timer will start at 2 hours (2.0) and it will then go to 1.45, etc. When you get to a 1/2 hour let go and it will start counting down. If, in the process, you make a mistake, press the blue button and don't let go. Hold it down until it erases the setting and removes the NAP text from the front display. Release button. Start holding down the button again. Once again, the display will go to two hours, continue to press button, it will start counting back in 15 minute increments. Again, when it gets to 1/2 hour, quickly let the button go. As the clock counts down, you cannot see how much time is left on the clock. Press the button, quickly let go again. It will display how much of the 1/2 is left. When the clock counts down to zero, either the alarm will sound or the radio will start playing depending on what you set the alarm to do. Press the off button, that's it... (0:
I am using my mother's Elgin 3400E travel alarm
On my Elgin alarm clock, you just push the nap button and it will add 15 minute increments for a nap. I haven't figured out how to turn it off if I change my mind or wake up earlier than I set it.
3helpful
How do I turn the NAP button off?
By pressing and holding the NAP button for several seconds, the NAP indicator is supposed to go off. However, I have the same model and the ability to turn off the NAP function after starting it went away. Hope this has not happened to you!
10helpful
2answers
Can't turn off nap.
Hold down the NAP button for at least 4 seconds until TIMER goes away.
5helpful
I can not find where to turn off the alarm until i reset the time.It alarms everyday
Hold down the mode button until the alarm/radio symbols disappear. (To turn of nap, hold down nap button.)
60helpful
3answers
RP3721A How to turn off NAP button
I've seen some comments that you can't turn NAP off once it's set.
You can turn off NAP by holding down the NAP button for a few seconds again once the clock has exited NAP set mode and is showing the time. When you first hit the button, it'll go back into NAP set mode (probably showing 0:20) but after a few seconds, you'll go back to the time with NAP off.
Trick is, the button's a little quirky, and you have to hold down just the edge closest to the back of the clock. The middle of the button or any other edge just throws you back into NAP time adjust but never turns it off. I have no idea why--must be a design or manufacturing flaw of some kind.
26helpful
2answers
Turning off "NAP" feature
You have to "double-click" the "NAP" button. And on the second "click," hold it down until the "NAP" light goes off.
That worked for me three times in a row, at least.
11helpful
6answers
NAP
JUST HOLD THE NAP BUTTON UNTIL IT NO LONGER IS BLINKING NAP, dont return it, its very good at waking you up in the morning, and is basically a good alarm clock, it just has a different way of turning nap off.
20helpful
6answers
Resetting clock
Press the SET button until you cycle through the alarms and the Colons on the time start to flash. use the right and left arrows from the CD buttons to adjust time; After time is set; press the SET button. Be careful to not fat finger and hit the CD button when pressing the SET buttons. That will turn on the AWFUL NAP timer. That's another headache.
. Stop the Nap alarm Press NAP to start NAP flashing. Press and hold NAP to cancel the nap setting. If this does not work; try again. It seems to take me a time or 2 to get it to work.
1helpful
2answers
Snooze alarm
Like everyone else here I have accidentally hit the NAP button and couldn't turn it off. This morning at 2am I accidentally hit it with my husband in bed. I decided one and for all to guide this out. By flashlight and my cell phone i Googled a solution. I came across many, none of which worked. I resorted to trying methods that were posted for other models of this brand of clocks. The solution that I found that worked was to hold down the back part of the NAP button until the seat the time displayed and the nap light off. By back part of the button I mean hold down the tiny section closest to the rear of the clock. I got this solution from instructions for model RP3721A clock. It took me 17 minutes.That's just 3 minutes before the alarm would have gone off.
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
