Refrigerators Logo
Anonymous Posted on Oct 02, 2011
Maytag model MSD2754FR - water tube to ice maker is freezing and causing water leakage and no ice cubes.
Anonymous
Level 3:
  • Master 2,341 Answers
  • Posted on Oct 02, 2011
Anonymous
Master
Level 3:
Answers
2341
Questions
Helped
636733
Points
7414
The reason that tube is frozen is because the water inlet valve is defective and not fully closing yet staying open a little and water is seeping through that tube and freezeing...its only a small drop but soon th enext drop freezes as well then before long a buch of little drops freezes resulting in the tube totally freezing. Replacing the water inlet valve will prevent the seeping thats the cause of it freezing up, the part number for that valve is 61005626 it could be purchased at your local appliance partstore or online at;
searspartsdirect.com
apdepot.com
repairclinic.com
apwagner.com
partselect.com
GENE
1helpful
The ice maker line freezes. I have thawed it, gotten water flow and one set of cubes but the line freezes again before in the time it takes to freeze the first set of cubes. What should I check next?
Check the water pressure or any filters in the water line or a crimp in the supply tube. Also make sure you totally defrost where the water enters the ice maker.
1helpful
Sub zero 532, ice maker issue. water enter the cube bin freeze into a block of ice with the cubes embedded. What is the cause of this issue?
There is a few things that you will need to check to isolate the problem. this first thing is locate the fill tube where the water comes into the ice maker. What you are looking for is any ice frozen inside causeing an overspray of sorts. If that checks good, then the next thing is look at the icemaker itself. Look at where the water goes to and freezes. Is it completely full of frozen water? if so then the water valve is sending too much water either because the ice maker called for it or the valve stuck and didn't close when it was supposed to. If its not full, look at the bottom of the ice maker, checking if there are any cracks allowing water to fall into the bin. My personal opinion though would be to change the ice maker and the water valve because of the age of the machine. the bad part is the actual icemaker for that model has been discontinued but I believe you can use a whirlpool style that matches, comes in a kit that has both the water valve and icemaker, and cost almost half the price as the original. that part number is 1129313
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
1helpful
Maytag refrigerator model MSD2754FR water line to ice maker is freezing solid leading to water leakage and no ice cubes. I thawed once with a hair drier but the line has re-frozen.
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Maytag model MZD2766GEW. The water tube supplying
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Ice maker will not make ice,have water but no ice.
Many people see this as a problem but if you take a look you have two separate controls for the ice and water system. So what's next? Look for a model number around the fresh food section door and sometimes your model number you may have looked at it every time you open the door and did not realize that is what that is. Locating Your Model Number or lets go to Maytag=> HERE and in the pull down choose if your model is a side by side or other than a side by side. Neat Tool! So now back to your ice maker and being the way most ice makers are they have a side to the water valve on their own somewhere near the water control valve on back of your refrigerator and near floor on most. The ice maker in most cases tells that water valve when the ice maker needs water again so many times it is the problem anyway. If your ice maker has cubes in it and still will not drop the cubes then it is the possibly the ice maker causing the problem but if you fill the ice maker with tap water and it freezes and then dumps cubes into the ice bin then the problem is the water control valve on the back of your refrigerator. Here is a short clip below. And here is a search for=> Maytag Refrigerator Water Control Valves and a search for=> Maytag Refrigerator Ice Makers I hope this has helped, Thanks, Sea Breeze
Here is how to=> Replacing The Water Valve on my Refrigerator
2helpful
2helpful
Ice maker doesn't work
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps the cubes , but doesn't fill with water , replace the water inlet valve ( the piece that the wall water line connects to on the fridge ) . Also check to be sure that the fill tube from the back of the freezer to the ice maker , isn't blocked with ice , as this is caused by a seeping bad water valve . If the ice maker doesn't dump the cubes , after freezing , then replace the ice maker . Also check to make sure the coils under the front of the refrig , are clean of dust , lint , pet hair , etc.
4helpful
2answers
Maytag msd2356ae ice maker will only give me hollow ice any ideas.
Hollow ice cubes are most often cause by insufficient water supply. Icemakers fill for about 7.5 seconds, resulting in about 4.75 oz. (140 cc) of water into the ice cube mold. If there s not enough water pressure available at the fridge, cubes may end up hollow and/or the fill could continue to dribble, eventually causing the fill tube to freeze closed.
pls rate my suggestion.........
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
