In the 24v system one battery has a negative ground and the other has a positive ground. If either battery is installed backwards everything will work (lights etc.) but the starter will not work. It is also possible to accidentally charge one of the batteries backwards if a battery charger is hook up wrong, which has the same effect as installing a battery backwards.
Check all grounds before further testing
