Janome D'cor Excel Pro 5124 Mechanical Sewing Machine Logo
Anonymous Posted on Oct 02, 2011
I need a manual for Janome Decore 5124 - Janome D'cor Excel Pro 5124 Mechanical Sewing Machine
Hassy
Level 3:
  • Janome Master 1,388 Answers
  • Posted on May 12, 2014
Hassy
Janome Master
Level 3:
Answers
1388
Questions
Helped
496006
Points
2943
Debbi's Sewing Machine Repair
Level 3:
  • Janome Master 7,365 Answers
  • Posted on Apr 05, 2012
Janome Master
Level 3:
Answers
7365
Questions
Helped
1741602
Points
19451
Did you ever get a answer to your questions you asked?
5 Related Answers
Anonymous
  • Posted on Jan 22, 2008
SOURCE: Came without an instruction manual
If you bought it new and there was no manual, the dealer you bought it from or Janome themselves will give you one. Meanwhile, the smaller knob on the side of the machine (bottom one) changes the type of stitches. As you turn it, you'll see the red indicator change on the front to show which stitch has been selected. Of the 3 sliding levers on the front of the machine, the top one numbered 1-6 controls the zigzag width. The slider below it, numbered 1-4, controls the stitch length.
Also, the needle has to be in the "up" position in order for you to be able to change the stitch type. If it's down, you can either push the "up/down" button, or turn the handwheel (larger knob on side of machine).
ndirons
  • Posted on May 02, 2009
SOURCE: Janome Excel 5124 reverse lever
If you pull the bottom off the machine (half a dozen screws) there is a cam on the main drive shaft. The cam is probably jammed in the reverse position due to lack of lubrication on the shaft. You can move the cam back manually and it will operate in forward direction. It appears that the shaft needs lubrication.
Anonymous
  • Posted on Jul 22, 2009
SOURCE: Janome 5124 keeps running after I depress foot
Greetings, I experienced the same problem. Mine only ran a few stitches. Foot pressure on the foot feed was always "tension" problem in my foot.
I turned the foot feed around and upside down.
I press on the foot feed at the open end not the pivot (cord) end. This has given me much better control. Janome had no options for foot feed adjustment or replacement, but this has helped greatly. You may have to practice to get used to it
Anonymous
  • Posted on Jul 22, 2010
SOURCE: need repair manual
try http://www.sewingmanualsonline.com/service-manual-janome-5018-and-5024-download.aspx
they sell them for download - very useful.
  • 7365 Answers
  • Posted on Jul 30, 2010
SOURCE: it is sewing loose or i can not get bobing tread
try these sites
sew usa
sewing manuals.com
ebay
How do I thread to use twin needles on Janome Excel Pro 5124?
here is a link for a manual, the information should be in it about the twin needles Instruction Manual Janome 5124
Janome twin needle
you should be able too, I sent you a link for a manual, the information should be in it.
2answers
Instruction manual for Janome Excel Pro 5124
did you ever get a answer to the question you asked?
1helpful
Lost the instruction manual janome decor excell II 5024 Pls email at the following email address
at janome website they have a operation manual
under machines it will show different names like embroidery-sewing/quilting
look for the one that says retired
it will bring up a picture under the picture it will say machines in this catagory
it has a janome decor excell 5124
4helpful
Lost my sewing instruction manual when moving house. Can't remember stitch patterns adjustments. Need a new sewing manual for my Janome Decor Excel 11 5024 Thank you
Hi
You can download some partial manuals from the Janome site.
This is for the Janome D'cor Excel Pro 5124:
http://content.janome.com/documents/File/ManualFile/DecorExcelPro5124.pdf
Which should be similar to the ohter model number you mention.
Hope this helps!
I need a user manual for my Janome 18excel please
Hi
The Janome site has a manual for the Excel 5124 but I couldn't find one for the Excel 18. It's quite a basic manual, in that it just gives help with the different parts and threading etc.
It should be useful as the two machines look similar.
http://www.janome.com/documents/File/ManualFile/DecorExcelPro5124.pdf
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
